Old 12-01-2003, 04:31 PM   #1
paintpyro
paintpyro's Avatar
front shock relocators
Anyone using Turners front shock relocators? My shock mounts are completely thrashed.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 12-01-2003, 05:59 PM   #2
Frank_Zeller
Frank_Zeller's Avatar
Yes. You need to weld a piece of metal between the frame rails under the mount to make it more rigged. The new top mount allows you to move the shock more straight up to get better performance.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 12-01-2003, 08:59 PM   #3
Andy4639
Old member
Andy4639's Avatar
Cool New Shock Mount
These are the ones I made and have been using now for over a year with no problems. The thing about these is you can put them where you want them. I made them out of 1/4" s/s. You have to cut the lip of the inner fender just enough to place it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
