Old 08-01-2019, 07:07 AM   #1
69Chummins
ACC Carpet Rockauto PSA
This thread is for those who are buying ACC carpet from Rock Auto.
I needed a high tunnel carpet for my 69 Chevy 2wd automatic truck (modified) so I ordered this:
ACC 19819340
https://www.rockauto.com/en/catalog/...,flooring,1264
It states that TH400 is a high tunnel. I should have done my research here on the forums. Consensus is that only the 4x4's got the high tunnels.
What I received was a low tunnel kit.
I did not discover the problem in time and could no longer return it.
I ended up ordering again. I ordered as a 69 K20 4x4 pickup:
ACC 20768340
Here are some pics to compare. The middle part is the transmission hump and the white label is the front.
Low tunnel
[IMG][/IMG]
High tunnel
I hope this helps and stops anyone from making the same mistake I did.
What a pain in the ass!
69Chummins is offline   Reply With Quote
Old 08-01-2019, 09:48 AM   #2
4X4GMC1972
4X4GMC1972's Avatar
Re: ACC Carpet Rockauto PSA
Big block, 4x4, or 2wd 4 speed are high tunnel
All others = low tunnel
1978 Dodge Omni
4X4GMC1972 is offline   Reply With Quote
Old 11-06-2019, 02:40 PM   #3
weim55
This!
I believe ACC is simply misinformed about the application differences for 67 to 72. If a cc used the simple and same guideline as above AND noted hi hump or low hump with those application guidelines it would end all confusion around ordering. I was about to order carpet myself in the next couple weeks and checked into it and noticed how confusing their application guideline is. Completely full of holes. My application is a 69 with a factory 350 and turbo 400 which is low hump. 69 396- Turbo 400 is a high hump from the factory, Hence the confusion. ACC must have endless problems with the customer receiving the incorrect carpet. I’m actually going to try to take this on and see if I can speak with somebody to straighten out this problem once and for all. Thanks all of you for your input, this will help me get the right product the first time!
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 08-01-2019, 11:32 AM   #4
leddzepp
Moderator
leddzepp's Avatar
Easy way to tell: High tunnels bolt in, small tunnels are welded in and integrated into the cab floor.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-01-2019, 12:56 PM   #5
Jason Banks
Jason Banks's Avatar
Wow...didn't know this... Yesterday I added the TH400 carpet to my Rock Auto shopping cart for my 2wd 4speed high hump truck that I am converting to automatic. I was afraid to order the 4speed carpet because I thought it might have a hole in it.
Jason Banks is offline   Reply With Quote
Old 08-01-2019, 08:36 PM   #6
firedemon
wow those are shiney when new
firedemon is offline   Reply With Quote
Old 08-01-2019, 09:58 PM   #7
dmjlambert
dmjlambert's Avatar
Very good information here. How bad and incorrect the pictures are, that ACC and Rockauto have chosen to represent the product. It is a crying shame.
dmjlambert is offline   Reply With Quote
Old 10-28-2019, 01:53 PM   #8
MDPotter
MDPotter's Avatar
I'm going through the same ordeal right now. I read this weeks ago and knew about the issue and went as far as emailing ACC to confirm that the "original 400 transmission was a high tunnel" carpet was correct for a high hump and they said yes. Low and behold, it showed up as a low tunnel. I have an email into Rock Auto right now asking them to send me one meant for the 4-speed which should be a high tunnel according to ACC. It is a different part number so hopefully it's correct.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 10-28-2019, 02:27 PM   #9
FirstOwner69
FirstOwner69's Avatar
Rock Auto is not the only one. Stock Interiors implies all TH400s require high hump carpet. When I searched for carpet for my '69 C20 with TH400 and low hump I got this "1967-1972 Chevy Full Size Truck, Standard Cab Carpet, 400 Transmission, High Tunnel". Luckily, when I saw this I became very cautious when I bought mine from Rock Auto.
FirstOwner69 is offline   Reply With Quote
Old 10-28-2019, 06:56 PM   #10
69-72
69-72's Avatar
I believe Stock Interiors is the same company as ACC If there was another choice other than ACC I would use them but it looks like ACC is the only company making carpets.\
I too had an awful experience with Rock Auto and ACC
Application was a 1972 Jimmy on which it matters what the binding at the rear edge of the carpet looks like since it can be seen. Long story short It took filing a claim with the BBB for RockAuto to get them to pay the return shipping charges which they promised to pay then changed their mind on.
After 3 different carpets seemingly made on what Im guessing was BirdBox challenge day at the factory It took an email to the owner of ACC to finally get a carpet made that had the edges trimmed straight and the binding sewn on properly.
Both companies also had extremely rude people dealing with customer service.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 08-05-2020, 08:59 AM   #11
OKGMC4
OKGMC4's Avatar
I know this is a little late but I've seen that TMI products offers a 3 piece carpet kit that looks pretty good. Costs a little more but maybe better quality? Thinking of ordering it.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 08-05-2020, 09:25 AM   #12
Green Monster
Green Monster's Avatar
It's nice to see there is an alternative but probably not one I would consider. It looks a bit choppy. TMI's carpet set has several seams on the separate middle section for the transmission hump up instead of one continuous form fitted piece like the original factory and ACC carpet set.
Green Monster is offline   Reply With Quote
Old 11-06-2019, 10:18 AM   #13
MDPotter
MDPotter's Avatar
ACC conceded that they sent the wrong carpet and through Rock Auto paid the return shipping and sent me the correct high hump carpet.
Old 11-06-2019, 11:27 AM   #14
GerhardH
GerhardH's Avatar
Thanks guys very helpful.
Best regards GerhardH!
Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20
1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400
http://67-72chevytrucks.com/vboard/s...d.php?t=760400
GerhardH is offline   Reply With Quote
Old 08-05-2020, 09:49 AM   #15
CarlsLQ9SS
CarlsLQ9SS's Avatar
I ordered carpet from rock auto also and ordered for a 1972 2wd with a 400 trans, w/o gas tank in the cab, and column shift. The part number is ACC 17901230, and used it in my 1969 cab with a high hump. I didn't have any issues at all with mine.
CarlsLQ9SS is offline   Reply With Quote
