![]() Join Date: Feb 2014
SPID is missing
Wanted to see if there was anyway i could find out what exactly my truck came with from the factory using the Vin # or what i needed to find that information out and see if there's someone that could make a new look alike SPID for the truck. Thanks for help guys.
Moderator
![]() Join Date: May 2007
Re: SPID is missing
Outintheshop.com
Contact Jeff. He makes perfect spid labels, and you can add any option you want.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: SPID is missing
If you are lucky there might be a build sheet in the seat springs or taped to the gas tank, or gas tank cardboard.
Steve weim55 Colorado |
Re: SPID is missing
Information for US built and sold trucks not available through GM until 1976/77.
https://www.gmheritagecenter.com/gm-...tion-kits.html If your truck was built in Canada, or built in the US for Canadian sale, then GM of Canada might have the original build info. https://www.vintagevehicleservices.com/ K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Re: SPID is missing
I found out that it was built in St Louis by the vin decoder and what it came with as far as the engine and transmission, just would like to know alot more.
Go Pack Go!
Re: SPID is missing
Sorry, there's nothing that will help w/o the build sheet.
![]() Join Date: Feb 2009
Re: SPID is missing
Like others have said, you pretty well need a build sheet.
But......................if you were well familiar with the truck history, and knew what you were looking at, it's possible to build a SPID with a lot of certainty. Just as an example, if the serial number on the frame matches title/cab, the frame was built a certain way (SBC Vs BBC), and the castings numbers on your long block are consistent with the truck assembled date. Good chance what was installed in your truck is what's in it. Requires a lot of research and experience, but you'd always have the caveat your SPID may not be accurate.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: SPID is missing
All the # on the frame and cab etc seem to match the vin # so I'd say its all original, just wanted to see if there's away that i could get a original Spid made for the truck looks like there's a guy that might be able to help me out. Thanks for all the replies and the good info you guys have given.
Re: SPID is missing
A good way to build a spid is to look at others and see what option whare available and mach what you have. For instance does your pickup have a chrome frount bumper. If yes it can be added to the spid. And so on with any other options you find your pickup has.
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
![]() Join Date: Oct 2009
Re: SPID is missing
While you can determine V8 vs I6 (but not which V8), unfortunately you can't determine transmission from the VIN.
Re: SPID is missing
If it's a Fremont truck (Z in the VIN) we've found them stuck to the front of the bed, trapped behind the cab.
#12 | |
Re: SPID is missing
Both mine are Fremont. It was under the bench in the 71, and it's behind the bench in my 72. Never actually read the 72 sheet. They're real brittle at this point, it's pull the seat or shred it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-02-2019 at 08:42 PM. |
