Old 08-03-2019, 11:51 AM   #1
cgster
72 C10 Lug Nuts
Bought a new set of 20 inch rims for my 72 C10 and the current lug nuts that are on my truck are to thick to get a 3/4 socket on the nut because the wheel hole is to narrow. What style lug nuts do I need so I can get the wheels installed? Thanks. Any links would be great.
cgster is offline   Reply With Quote
Old 08-03-2019, 02:41 PM   #2
kwmech
Re: 72 C10 Lug Nuts
Probably from the people that designed the rims without a large enough hole
Old 08-04-2019, 12:59 PM   #3
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Re: 72 C10 Lug Nuts
Look for spline drive type lug nuts. I bought a set of 32 for my C20 from Amazon for about $26. A lot cheaper than the auto parts store
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 08-05-2019, 10:46 AM   #4
72ChevyTruckss
Re: 72 C10 Lug Nuts
warning, 72 C10 lugs are short, Aluminum wheels are thick.
Highly advise you check thread engagement, mine only had 4 threads holding them on.
I replaced all my lugs on my 72 C10 with longer studs and new lugs.
72ChevyTruckss is offline   Reply With Quote
