Old 08-03-2019, 09:44 PM   #1
flattie39
Junior Member
Horn honks when turning
Hey Guys - This is driving me nuts and I need some suggestions on how to correct it. I have a 69 C10 Stepside with the original 250 inliner and stock non-tilt steering column. I'm swapping my stock 17" steering wheel for a 15" (need the extra room) out of a 57 Chevy Two-10. I can get it to honk using the horn ring OK but it also honks when turning a corner, either direction. Any ideas?
Thanks, Ken
flattie39 is offline   Reply With Quote
Old 08-03-2019, 09:59 PM   #2
Willys_MB
Willys_MB's Avatar
Re: Horn honks when turning
Horn wires are probably shorting our inside the column. This happened in my old Jeep. Might be worth investigating.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 08-03-2019, 10:10 PM   #3
dmjlambert
dmjlambert's Avatar
If you remove the horn ring and horn button, does the problem go away or remain? That is how you determine where the problem is. Is the problem in the column or in the steering wheel?
dmjlambert is offline   Reply With Quote
Old 08-04-2019, 07:53 AM   #4
Zeroman
Zeroman's Avatar
I had the same issue. Drove me crazy until I started looking at why it happens.
The horn ring was contacting the turn signal lever hold down screw, but only when pressure was being put on the steering wheel during turning. Mine would also honk if I pulled back on the turn signal lever.
Depending on which after market wheel adapter you purchased, there is usually a thin steel washer, maybe 3/32" thick, that needs to be installed on the column shaft first before the adapter hub. The washer spaces the hub off of the horn ring so when you tighten the shaft bolt down the adapter does not force the horn ring towards the front of the column.
You can see the ring in the picture attached.
I had installed the hub first, then the washer because I did not have any instructions as the adapter kit I installed was new, but over 20 years old.
I would call the manufacturer to verify.
Zeroman is offline   Reply With Quote
Old 08-04-2019, 01:50 PM   #5
VWNate1
VWNate1's Avatar
Post Re: Horn honks when turning
There's also a bushing /bearing in the top end of the steering column mast jcket that wears out and a few times at the Dealer the wire leading from it got apinched and simply wore through, back then it was a $7 part or some tape and proper routing of the wire would fix it on the cheap .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 08-05-2019, 10:43 AM   #6
72ChevyTruckss
yep, horn signal shorting to turn lever screw. possible missing a spring to keep the horn collar away from turn lever screw.
72ChevyTruckss is offline   Reply With Quote
Old 08-05-2019, 12:03 PM   #7
68Gold/white
Quit turning!!!
68Gold/white is offline   Reply With Quote
Old 08-05-2019, 12:36 PM   #8
truckster
truckster's Avatar
It's not a bug; it's a feature.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 08-05-2019, 03:33 PM   #9
flattie39
Junior Member
Thanks for the replies Guys - I've been on the road for the last 4 days and haven't been able to respond. I will try all the suggestions tonight.
Truckster - If I can't fix this honking problem, I'll use the horn as my turn signal and disconnect the turn signal lights.
Thanks again, Ken
