Electric fan recommendation.
1970 C10
350 cu 350 auto Mostly stock but has eddy carb and champion aluminum radiator. Truck starting to heat up during parade. No air flow of course just ideling. Sometimes it will heat up a bit in stop and go traffic on real hot days. Cleveland Ohio. Just have stock temp gauge so don’t use exactly how hot. Have to check next time with IR gun Question is Going to either add a pusher electric fan to what I have or remove mechanical fan and add a puller? Thoughts? Lastly I want to get a fan kit with everything I need if possible. Temp sensor for intake manifold and relays needed. Anyone recommend a good unit kit that won’t break the bank. Thanks! Mark Posted via Mobile Device Last edited by rockyrivermark; 08-04-2019 at 02:50 PM. |
Post Whore
![]() Join Date: Feb 2016
Re: Electric fan recommendation.
What fan does it currently have? Is the shroud intact and installed correctly? Clutch fan? Can you post pictures? I went from a 4 blade stock fan to a factory 7 blade clutch fan it made a difference on my Burban. I idled for more than 10 minutes on Friday afternoon (it was 80*) and the temp guage barely moved.
I'm not a big fan of pusher fans (no pun intended) they are a poor band aide at best in my opinion.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Nov 2018
Contact Champion they should have a electric fan/shroud kit to fit your existing radiator.
20' Daredevil (Ret)
![]() Join Date: May 2003
I agree with HO455, before you add or change stuff, what is your existing setup?
Currently stock fan. No clutch and stock shroud
Posted via Mobile Device |
20' Daredevil (Ret)
Your stock fan, is it a fixed-blade unit? Maybe 4 blades?
FWIW -- my K20 with factory A/C came stock with an 18" seven-blade fan and a heavy-duty clutch. The clutch finally failed about 3 years ago and I replaced it with a virtually identical Hayden #2747. It works flawlessly, the truck can idle for long periods of time in 100-degree temps. The fan is not noisy -- you can hear it when engaged but it's certainly not loud. A proper electric fan would likely do the trick for you, but to me it's just not worth the trouble to make the change. For my money, I would use what GM designed for it, which is what I have. You already have the shroud which is a big plus. Whatever you decide on, if you don't already have a coolant recovery tank, it's worth getting. It allows you to fill the radiator all the way up and nothing pukes on the ground. You'll need to use a radiator cap for a sealed system.
Post Whore
How many blades on the fan? The fan in the photo I posted earlier is stock for a HD cooling or camper special. They came with the 4 row radiator package.
![]() Join Date: Nov 2006
it wont keep it cool from my experience
I BELIEVE IN JOHN 3:16 |
![]() Join Date: Dec 2013
We didn't have all these overheating issues in the 70's . it's the ethanol fuel . try using real gas . Your not too far away from a real gas station .
Ethanol burn hotter meaning car engines run hotter. One of the bad things that happens when ethanol used as a fuel is that car mileage will actually decrease. The New York Times stated that E10 gasoline, which is the gas used in America, actually provides 2-3 miles per gallon less than gasoline.Sep 7, 2017 Ohio real gas stations . ![]() https://www.buyrealgas.com/Ohio.html https://extension.psu.edu/fuel-ethanol-hero-or-villain
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Its a Truck Thing......
I changed mine to a Jeep fan and added a pusher for the ac condenser. Had it on for many years and haven't had any issues even down here in the Zona. I wired mine with a override so I can watch the temp and adjust as necessary. I agree with Grumpy on the Fuel, I hate Ethanol and hope soon it gets pulled out of the fuel business. I also did wiring changes to accommodate the increased amps on the system. My buddy who does LS tuning told me that the new camaro fan is what the guys are running now. I'll look for my post on my upgrade.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
