Old 08-04-2019, 09:50 PM   #1
michael bustamante
michael bustamante's Avatar
Grounding straps.. what's needed?
So I'm at the parT now where I am attaching the ground straps before I do my initial start up. Grounded the harness at the battery negative cable (since moved to the back of the block) and I ran a strap From the Block to the frame and from the back of the block to the firewall (edited) . What other straps are needed?
1967custom
michael bustamante is offline   Reply With Quote
Old 08-04-2019, 10:02 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Grounding straps.. what's needed?
(From the Block to the frame and from the back of the block to the fire alarm.)...fire alarm???..haha
Everything needs grounded...battery to engine....engine to frame...frame to body...body to engine...cant have to many grounds...
even the fire alarm needs grounded...haha
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-04-2019, 10:18 PM   #3
michael bustamante
Hahaha. Gotta love speak to text!!! . To the fire wall!.. looks like I got them all then. Great I just grounded my headlights and they popped on instantly so I think I'm on the right track here felis
1967custom
Old 08-05-2019, 03:21 AM   #4
Madkidd007
Madkidd007's Avatar
Not sure if a reworked stock harness or what. But does your harness have engine ground wires itself like a stock harness that usually ground to the back of the head and/or bellhousing bolts?
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 08-05-2019, 04:52 AM   #5
ls1nova71
ls1nova71's Avatar
Originally Posted by michael bustamante View Post
So I'm at the park now where I am attaching the ground straps before I do my initial start up. Grounded the harness at the battery negative cable on and I ran a strap From the Block to the frame and from the back of the block to the fire alarm. What are the straps are needed?
What I want to know is why are you doing this in a park?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-05-2019, 02:50 PM   #6
michael bustamante
damn smart assesLOL AT the PART!!
Im using the stock harness I reworked. at the harness Igot three gounds mated at the back of the passenger half of the block next to the Head.. got the block grounded to the firewall at the motor /tranny mount. and gounded the engine to the frame at the now missing a/c compressor mount location. also grounded the battery to the engine. should I ground the battery to the body as well ( at the fender) or is it not necessary?
1967custom
Old 08-05-2019, 03:04 PM   #7
sprint_9
sprint_9's Avatar
I'm glad this is all cleared up, I was going to post last night but was confused on exactly what was going on.
I would ground the body too. On mine I ran one from the battery to the core support. I have alot of stuff grounding to the core support so I wanted a good path. Stock setup included a wire to the passenger fender I think.
sprint_9 is offline   Reply With Quote
Old 08-05-2019, 03:18 PM   #8
michael bustamante
I think so too. Ill run one tonight when I get home. hopefully the headlights will get a little brighter
1967custom
Old 08-05-2019, 04:36 PM   #9
Madkidd007
Madkidd007's Avatar
I’m with y’all on this, do that one more direct battery to body ground and I’d say you’re golden except for one spot that’s not related. I always add an additional frame to bed ground so I guarantee all my sheetmetal has a solid ground
Old 08-07-2019, 12:29 PM   #10
cebra
All of my original start up issues were due to poor ground on the LS. I have battery to frame (ground down paint), battery to motor, frame to motor, 2 firewall to motor and I used the biggest cables I feasibly could. The Battery to motor and grinding down the paint on the battery to frame were the ones that cured my non-start issue. The frame to motor was just an add-on after the fact to make sure I had plenty.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 08-08-2019, 05:26 AM   #11
KMAT
What size straps are needed for all this grounding?
KMAT is offline   Reply With Quote
Old 08-08-2019, 11:23 AM   #12
First c10
First c10's Avatar
This is what I made.
its like #10 flat tinned grounding strap. I soldered the connectors on. Its was a lot cheaper then buying them already made and you can make custom lengths.
I bought a 25' roll and the connectors on amazon or eBay.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 08-13-2019, 03:45 PM   #13
cornerstone
cornerstone's Avatar
Looks great!
What width did you buy? For a 25 foot roll, Amazons pricing is kind of weird, the
1/8” is $18.
1/4” is $20.
3/8” is $54.
1/2” is $100.(EDIT) elsewhere on Amazon for $25.
5/8 is $98.
1/4” Ring terminals are $9. for 25 pc.
Thanks ...... - Brian
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 08-13-2019, 03:53 PM   #14
First c10
First c10's Avatar
Originally Posted by cornerstone View Post
Looks great!
1/8” is $18.
1/4” is $20.
3/8” is $54.
1/2” is $100.
5/8 is $98.
I believe they were 1/4" wide maybe 5/16" I will have to look i know its was like 30 bucks for the wire and terminals and I can make many of them!!!
GO GO!!!
Old 08-13-2019, 04:01 PM   #15
cornerstone
Cool. While on Amazon I noticed there is also the same kind of braided strap, but in copper. ( without the tin added ) do you know if there an advantage to either? If my memory serves me correctly the factory ground straps were just copper.
Thanks again!
Brian
Brian
Old 08-13-2019, 04:59 PM   #16
First c10
First c10's Avatar
I went the tinned copper route as it does not tarnish as fast. Stock was raw copper.
GO GO!!!
Old 08-25-2019, 09:48 PM   #17
Gregski
Post Whore
Gregski's Avatar
I ripped all of the ground wires out of the stock factory wiring harness to show people what they all look like, there are three grounds and they are all connected together, it's all one continuous ground circuit
Gregski is offline   Reply With Quote
Old 08-25-2019, 09:51 PM   #18
Gregski
Post Whore
Gregski's Avatar
once I reworked my wiring harness I did it in such a way that all my 3 factory grounds bolt to the back of the driver side cylinder head as well as the ground strap which runs to a bolt on the firewall to ground the cab, trucks runs amazeballz
