08-05-2019, 12:07 AM | #1 |
Currently Blazerless
NOS GM Hydro Boost Unit
NOS mid 80s GM hydro boost unit 120.00 shipped plus Paypal fees
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
08-06-2019, 02:16 PM | #2 |
Re: NOS GM Hydro Boost Unit
Hello......what else is required for this to function?
Thanks, Greg
72 Cheyenne Super 350 Holley EFI/700R4 67 Camaro SS/RS 68 Corvette 427 Tri-power 4-speed convertible 55 Chevy Belair Hardtop |
08-06-2019, 07:29 PM | #3 |
Do you have the rod that goes to the master cylinder? Do you have a part number I could do a little more homework? Is there a box?
72 Cheyenne Super 350 Holley EFI/700R4 67 Camaro SS/RS 68 Corvette 427 Tri-power 4-speed convertible 55 Chevy Belair Hardtop Last edited by bcnya2; 08-06-2019 at 08:17 PM. Reason: Wrong word |
08-06-2019, 07:33 PM | #4 |
You would need a master cylinder and hydraulic lines to tie into your power steering pump. The mounting bracket on this one can be modified to fit the factory mounting or there's a guy on this board that sells a special bracket he makes that allows you to bolt it right up.
08-08-2019, 09:39 PM | #5 |
Sorry somehow I missed this post. No I dont have a pushrod for the master cylinder. I can find a part number on the unit itself and dont have the box. Ive had it on my parts shelf since I got it back in 01. I was told it was mid 80s, I believe the same unit was used between 2 and 4 wheel drive and even CUCVs. The guy I got it from dealt in CUCV parts.
08-08-2019, 09:52 PM | #6 |
Here is a reman unit for a 1990 square body suburban for comparison. The only way you’ll buy the correct rod is used, in my case I cut down a rod from a vacuum booster. Also if I remember correctly by bracket looked like the one pictured before I cut the extra off.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
08-08-2019, 09:59 PM | #7 |
This is by no means meant to be an insulting offer but if for some reason it doesn’t sell I would give $60. Just know I would be valuing it as a core not as a low ball offer
08-16-2019, 10:38 PM | #8 |
Last chance before it goes back on the shelf. 85.00 Shipped
10-20-2019, 01:56 PM | #9 |
Hey Blazerman, any part numbers on the hydro boost for cross reference? Thanks
11-05-2019, 10:17 AM | #10 |
someone mentioned that there is a person on here that has the bracket you need, lookup CaptainFab, this guys makes them and they are perfect. He makes them based on years also. Good Luck
