08-05-2019, 08:42 AM | #1 |
Help identifying this noise
So, starting a few days ago I started getting this medium pitched flappy/farty noise on the initial acceleration. It only seems to happen when its a cold start and it only happens for a few seconds at most. If I feather the gas pedal really lightly, it doesn't seem to make the noise and after a couple minutes of driving it doesn't happen at all. I think it has to be drivetrain related, but can't seem to pinpoint the source with my ears. Everything under the truck and in the engine bay seems normal. Maybe something in the transmission (its an auto) ... any ideas?
Also, in the video I just happen to be turning, but it doesn't have anything to do with that. https://youtu.be/ttkCLqhNw-8
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 Last edited by dmw319; 08-08-2019 at 08:53 AM. |
08-05-2019, 02:20 PM | #2 |
Re: Help identifying this noise
Exhaust leak?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
08-06-2019, 08:21 AM | #3 |
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 Last edited by dmw319; 08-06-2019 at 09:45 AM. |
08-06-2019, 08:23 AM | #4 |
its also made this noise a few times recently.. its when I am slowing down its like making a clunking noise.. it happened most of the way home from work then quit. didn't make the sound this morning though.
https://youtu.be/OyWZDKhZLhk I have taken the truck to the transmission shop and they said they couldn't find anything wrong with it.. so.. I'm still at a loss.
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 Last edited by dmw319; 08-06-2019 at 09:44 AM. |
08-06-2019, 10:19 AM | #5 |
08-08-2019, 07:50 AM | #6 |
To me it sounds like a heat shield rattling.. but my truck doesn't have any
As for the brake noise... I still got nothing. I took the wheels off on both sides and everything looks normal brake/suspension wise.
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
08-08-2019, 08:22 AM | #7 |
Did you check motor mounts or centre bearing?
08-08-2019, 08:47 AM | #8 |
just a visual inspection and they both looked fine. ill double check this next time I'm under there!
08-08-2019, 09:10 AM | #9 |
Might need to use a bottle jack to lift the motor to check the mounts.
Visual inspection doesn’t always work well. |
08-08-2019, 09:23 AM | #10 |
Long bed truck? That clunking sound would the center bearing, my guess. It seems to be on deceleration only.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
08-09-2019, 08:15 AM | #11 | |
shortbed. ill have to check it. seems odd it would only have intermittently though, right? I feel like once it starts to go it would just get worse but it hasn't happened the past two days.
10-09-2019, 08:29 AM | #12 |
So.. I found/fixed one of the sounds today. It was the transmission flex plate cover. I don't know why it was vibrating and making that buzzing/farting noise.. but when I pressed up on it just barely, the sound went away. It wasn't loose or anything. So... I just removed it and the sound is gone completely.
The braking clicking/clunking hasn't happened in a few months so I'll just worry about that if I continue to hear it. Thought I'd post a follow-up in case this happens to anyone else. How important are these covers anyway? Figured I could just leave it off permanently.
