12-01-2003, 08:33 PM | #1 |
transfer case trouble!!
I snapped off the output shaft of my transfer case, and I'm not sure what model it is or where to locate parts or a replacement. I know its not a NP 203, it has dana on the housing. Can you guys tell me what model it is, and what I can replace or fix it with? If it is a model 20, is it compatable with the jeep model 20's? My case is behind a 350 and a four spd manual, in a 70 blazer. Thanks in advance, Willie
1970 Blazer CST 350 700R4 |
12-01-2003, 08:38 PM | #2 |
Collector of rusty Items
Which shaft did you break off? Front or rear?
I never heard of a dana case in a 70 chevy, But I don't know anything about blazers.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
12-01-2003, 08:55 PM | #3 |
It was the rear shaft-
12-02-2003, 02:49 AM | #4 |
output shaft
there was dana 20 cases behind the 3 speed blazers. what you should have is a 205. is the output shaft broke or is the yoke? ive neverseen a output broke. how many splines does your have? i have a ton of 4x4 stuff let me know how many splines ill se if i can find one in my organised mess
12-02-2003, 12:24 PM | #5 |
Hey Tr-acer,
You got a 32 spline front shaft and bearing cap etc in your cache?
12-03-2003, 12:04 AM | #6 |
dana t case
i just found out you might have a dana 20 behind that 465. i ll find out what spline count those are and if the jeep 20 stuff is interchanceable.
12-03-2003, 02:35 AM | #7 |
I had the same t-case in my 69 blazer. It is a dana 20. Its odd that yours has a 4 speed because they only came behind 3 speeds (or thats what I thought). I called advance adapters years ago about this t-case and they said that it is on its own. Meaning there is no other t-case like it. They actually wanted to buy my case so they could do research on it. That was back in 1994 so Im sure things changed since then. Dont know if you could swap parts out of another dana 20 or not. If it was me Id put a 205 in it and be done.
