Old 08-06-2019, 10:41 PM   #1
Jason 56
6l90 compatibility
I’m to the point in my build where I need to obtain a drive train. I’d like to use a 6.0 L and 6L90. Is the 6L90 TCM compatible with a LY6 or do I have to go with the L96
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 08-07-2019, 04:33 PM   #2
Jackson's Dad 64 C10
Jackson's Dad 64 C10's Avatar
Re: 6l90 compatibility
I'm not the expert here by any stretch of the imagination, but I picked up a complete take out from a 2011 Silverado 2500 last year. It is an LY6 with a 6L90 as the factory drivetrain. I have the computer, harness, etc. Since they were a factory combo, I would think that you can find one. I'm not sure what other transmission options backed the LY6, but I'd probably try to find a matched set. That way the computer is already ready to go. I'm sure that some others with more in depth knowledge will chime in soon.
Good luck!
Chris
Jackson's Dad 64 C10 is offline   Reply With Quote
Old 08-07-2019, 07:01 PM   #3
Madkidd007
Madkidd007's Avatar
The only issue that you can’t get around is your crankshaft. You have to use a 58x relcutor, a 24x is not compatible with any of the controllers for a 6 speed
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 08-07-2019, 08:58 PM   #4
Reluctor wheel shouldn’t be an issue when using the factory PCM/ECU/Whatever GM called the computer that year, as long as you’re using a factory engine trans combo... It would be an issue with a standalone aftermarket controller, i.e. if you wanted to carb the engine.
Old 08-07-2019, 09:30 PM   #5
Madkidd007
Madkidd007's Avatar
Actually it’s an issue with any combo using a 6 speed auto. No matter what combination, matching or not. The 6L trans series requires a 58x relcutor. Hence the reason you can’t swap an 06 tbss LS2 with a 6 speed but 07 and up you can. To directly answer the original posters question as long as you get a true gen 4 motor with a 58x relcutor you’re good to go. I say true gen 4 because in 06 LY6 engines were still using a 24x crank with everything else being gen4. Example my 06 5.3 LY6 24x had DOD using an E40(LS2) ecm and T42 trans module.
Tbssowners.com is a good place to research this as 07-09 owners have been known to upgrade from the 4L70E that I’m unfortunately stuck with.
Old 08-07-2019, 10:02 PM   #6
Jason 56
Thanks, this is what I thought. I was planning on finding a Gen IV engine which I can source locally. The trans I’ll have to find on eBay. I live way up north near Lake Superior n to find a 2wd up here is rare. Everything is 4wd
Old 08-07-2019, 10:13 PM   #7
Madkidd007
Madkidd007's Avatar
Don’t rule out a 4WD yet. Do your research on the speedometer issue because if you have to use something from advance adapter that requires an output shaft swap then a full dissemble with happen anyways.
Am I correct that the ECM will just have to be reprogrammed so it recognizes the 6L90
This will all just depend on the donor engine harness, but either way it’s doable
Old 08-07-2019, 10:14 PM   #8
Jason 56
Old 08-12-2019, 03:55 PM   #9
AMERICAN PICK-UP
Find you a late model chevy 2500 express van complete matched pullout.... they are most all 2wd and 6.0 L96 mated to a 6l90e..... i have sold 3 of them already this year. i just sold a 2018 model with 20k miles.... they are out there...
AMERICAN PICK-UP is offline   Reply With Quote
Old 08-16-2019, 08:46 PM   #10
rowdy11
If you plan to keep the original transfer case, you will have to install an adapter from your NP205 to 6L90. Worth it IMO to avoid having to go drivers side Tcase drop and change out your front axle.
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
