Old 08-06-2019, 10:51 PM   #1
General23cmp
Best aftermarket fender emblems?
I know the purist will say to use originals, but what company have you used with good results for new fender emblems?
1972 Cheyenne 10 Super, so I need both of those plus the engine size one at the front on each side.
General23cmp is offline   Reply With Quote
Old 08-06-2019, 11:15 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Best aftermarket fender emblems?
I only have limited experience with these but have been impressed. I'm betting most of the big sellers may also sell TRIM Parts emblems.
https://www.trimparts.com/
FirstOwner69 is offline   Reply With Quote
Old 08-06-2019, 11:19 PM   #3
General23cmp
Thanks. I have noticed the aftermarket glovebox super emblems are easy to spot with the wrong woodgrain pattern behind the letters. I have the original there. I don’t see how the external emblems could be that obvious as the design is much simpler.
Old 08-06-2019, 11:28 PM   #4
FirstOwner69
Can you tell if this one is correct?
https://www.trimparts.com/9740
Old 08-06-2019, 11:48 PM   #5
General23cmp
Yes, looks aftermarket. Look on the classifieds at original ones, and you’ll see what I mean. The brown area should look more like woodgrain than that does.
Old 08-07-2019, 12:01 AM   #6
Jonny Hotnuts
I like these Fender emblems. These are made by Fender and were first used on the brownface and blackface amps in the early 60s. The reproductions (*made by Fender) are very close to the originals.
https://shop.fender.com/en-US/parts/...994093000.html
~JH
Jonny Hotnuts is offline   Reply With Quote
Old 08-09-2019, 07:05 AM   #7
bigmac73
bigmac73's Avatar
you might have missed the mark here???
~JH
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 08-09-2019, 09:10 AM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I literally had red paint flaking off one of my Cheyenne 20 emblems before my K20 had ten miles on it. Same problem later cropped up with the emblem on the opposite fender. Unsure which manufacturer but both POS emblems were since replaced with NOS emblems.
Old 08-09-2019, 11:54 PM   #9
toolboxchev
~JH
I worked for the firm when it was still in Lake Zero. Talk about a Pearl Jam for America.
What's happening to my Country???? I Digress just like above. Don't ever call me for your Daughter.
toolboxchev is offline   Reply With Quote
Old 08-10-2019, 04:57 AM   #10
GMCPaul
We carry the GM certified Trim Parts brand emblems.
Chevrolet Emblems Exterior
https://gmcpauls.com/Emblems.htm
GMC Emblems Exterior
https://gmcpauls.com/gmc_emblems.htm
Interior Emblems
https://gmcpauls.com/interior_emblems.htm
Paul Jr. @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 07-10-2020, 04:03 PM   #11
General23cmp
Interior Emblems
Paul Jr. @ GMCPauls
Very disappointed in the emblems I just received. They are Counterpart brand, not Trim Parts as I was expecting.
Old 07-10-2020, 04:16 PM   #12
tristan
GMC Paul's all the way!
tristan is offline   Reply With Quote
Old 07-10-2020, 04:22 PM   #13
GMCPaul
Counterpart buys the emblems from Trim Parts.
Above statement I now know is incorrect
Had the office contact Counterparts and they stated they've been changing over to their own tooling on the emblems which we were not aware of. We are going through the emblems checking those without Trim Parts labels for quality and correctness and will switch on any emblem that is not of the highest quality available.
Counterparts makes several good parts that we source from them because they offer higher quality than others but there are other items they make we source elsewhere due to a different manufacturer supplier offering a higher quality. We do this with every part and supplier that we buy products from.
Paul Jr @ GMCPauls
Old 07-10-2020, 11:49 PM   #14
HO455
Post Whore
HO455's Avatar
Oh I would disagree. He hit my funny bone dead center.
RIP Bob Parks.
