Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 08-07-2019, 10:36 PM   #1
ts3342
Stock 42
Have a friend that has a stock 1942 half ton truck
.He wants to change from drums to discs on the front. Who makes a conversation and where can he buy. Also he wants to put a new master cylinder with booster.
ts3342 is offline   Reply With Quote
Old 08-15-2019, 10:32 AM   #2
ts3342
Re: Stock 42
anyone?
Old 08-23-2019, 06:46 AM   #3
dennislbrooks
dennislbrooks's Avatar
Re: Stock 42
I would also like to have power steering on a stock 3/4 ton 46. In your case finding a rotor/hub that fits on the stock front axle spindle may not exist.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 10-01-2019, 01:01 PM   #4
VWNate1
VWNate1's Avatar
Post Upgrade Front Brakes
The brakes on this rig are "Huck" (rhymes with 'suck' for good reason) and were used from 1937 through 1950 on passenger cars and 1/2 ton trucks so go find how they converted those and have at it .
IIRC you'll need to drill out and re tap one hole per spindle, back in the day we'd up grade to 1951 ~ 1967 Bendix drum brakes using stock 1/2 ton parts, it's pretty simple and you don't even need to change the master cylinder .
I have the entire front axle drum to drum from a 1959 3100 in my back yard ~ saved for just such a project that never occurred, it's for sale dirt cheap to anyone who needs it .
The axle & tie rods are bent, it's from an old farm truck that was Hot Rodded .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
