08-07-2019, 11:04 PM | #1 |
Bouncing speedometer needle
Ok so whenever I have the gauges hooked up the tach and speedometer needles bounce. The tach was a N.O.S. sunpro super tach ii that my father had laying around and I'm guessing it's a bad ground issue. The speedometer on the other hand I'm not sure whether it's a cable issue or a gear issue. I just know it bounces constantly. Haven't been able to take it out lately as I've been busy with work but would anyone know if it's the cable needing to be lubed or if it's a bad speedo gear going from the trans to the speedometer cable and what size it'd be if I had to replace it. It's a Saginaw three speed and I'm pretty sure it's never been rebuilt
08-07-2019, 11:15 PM | #2 |
Re: Bouncing speedometer needle
When my speedometer needle kept jumping around it turned out to be a lubrication issue for the cable.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
08-07-2019, 11:20 PM | #3 |
Put a new cable in, yours is kinked.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
08-07-2019, 11:34 PM | #4 |
Who Changed This?
Did it do it before you reconnected the cable? It could be as simple as the cable isn't all the way on the speedo. When we got my FiL's truck, the speedo was noisy. All it took was lining the cable up in the speedo head and getting the nut on all the way.
08-08-2019, 12:02 AM | #5 |
20' Daredevil (Ret)
Could be a lubrication issue -- if so, I used white lithium grease decades ago and not had any problems. I have heard there's something better but I can't recall what.
08-08-2019, 08:41 PM | #6 |
Graphite powder. Sometimes sold as lock lube.
Doesn't congeal like white lithium. To be honest, I just look at the GPS on the freeway.
08-08-2019, 10:17 PM | #7 |
Post Whore
I had the same problem after I moved the cable about 1/2" for my new front shock mounts. Bouncing needle and noisy. I sprayed some white grease in the speedometer end and it slowly got better over about fifty miles and has not been an issue since.
I assume it was because the cable had taken a set after 48 years in the same spot and like everyone does it started complaining when things changed.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-08-2019, 10:51 PM | #8 |
20' Daredevil (Ret)
I thought I remembered something about using graphite -- searched & found this by Leon:
08-08-2019, 11:14 PM | #9 |
I have the same problem about once a year. Unscrew cable at both ends, Undo 1 or 2 bolts under the hood and the entire unit should come out.
I cleaned out the both the cable housing and cable with WD 40, sprayed a generous amount into the housing. Cleaned again than relube with some type of light grease or oil of your choosing. Works like a charm. Dirt is your enemy here. |
08-09-2019, 01:40 AM | #10 | |
I once thought white lithium spray grease was the neatest thing since sliced bread. I rebuilt a distributor's weights and springs and really dosed it good with the stuff. In under a year it ''clabbered up'' and gummed up my advance weights. I still use it on door hinges for instance, but I'm leary of using the stuff everywhere.
08-09-2019, 09:36 AM | #11 |
Yes white lithium is a dirt attractant. More uses in the boating industry, Salt water applications
08-09-2019, 11:13 PM | #12 |
If it only bounces at lower speeds it usually is the cable. If at all speeds, it is more than likely in the speedo cup or the head unit on speedo. I have had them bounce and had them professionally cleaned out and recalibrated with success.
08-10-2019, 05:15 AM | #13 |
My speedo works OK up to about 45 - 50. At freeway speeds 65 - 80, the needle bounces between both those numbers. If it's mounted in the cab, I use the GPS for accuracy and ignore the speedo on the freeway.
It's the original instrument from 1968, and has clocked over 390 K.
