Old 08-08-2019, 06:58 PM   #1
Nima
Blue 67
How to remove bellhousing bolts?!
Hi:
What is the best way to access these two lower bolts?
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 08-08-2019, 07:53 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: How to remove bellhousing bolts?!
Drop the clutch and pressure plate, and probably the flywheel, out the bottom, it looks like.
~Steven
Simi Valley, CA
Old 08-09-2019, 12:01 AM   #3
Nima
Blue 67
So, how do you install the clutch back? What I knew was bolting up the disc and clutch, torque them down while using alignment tool and then install the bell. I thought the removal is opposite.
Old 08-09-2019, 12:14 AM   #4
geezer#99
geezer#99's Avatar
Not on that bellhousing.
It’s like Steve said.
Slide the plate and disc out and unbolt the flywheel and take it out.
Then you can remove those two bolts from inside the bell and the rest of the bell bolts to separate the bell from the motor.
It’s easy like you have it.
A real hair puller laying under the truck.
Old 08-09-2019, 12:23 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
What are we looking at? Is that a 250 or the earlier 235?
Old 08-09-2019, 12:31 AM   #6
RichardJ
Looks more like an old 216. That bent rod/lever on top of the housing is for the foot operated starter. 6V starter, no solenoid.
There are four bolts behind the flywheel.
RichardJ is offline   Reply With Quote
Old 08-09-2019, 01:29 AM   #7
'68OrangeSunshine
How similar were the 216 - 235 - 261 Series? Totally different or diameter-different bores on the same relative block?
Old 08-09-2019, 09:18 AM   #8
MJN
MJN's Avatar
Its a 235, all 6 cylinders with the foot pedal starter had that linkage regardless of 6 volt (prior to task force 55.2-59 trucks) or 12 volt (55.2 and newer). The key switch on 6 cylinder trucks was simply an on/off switch. V8 equipped task force (55.2-59) trucks used a normal key switch starter as we all have today. I have the same setup from my '56 3600 pickup, just haven't gotten to the point of pulling the trans off the bellhousing yet.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 08-09-2019, 12:32 PM   #9
HO455
Post Whore
HO455's Avatar
On my 51 GMC I was able to get those bolts off without pulling the clutch components. If memory serves me I used a box end wrench and a large pail of patience. I had to do them equally as they were too long to do without backing the bellhousing off.
RIP Bob Parks.
Old 08-10-2019, 02:47 PM   #10
Nima
Blue 67
Well, it has been taken apart! Thanks for the help.
I took the clutch and flywheel out. I don't how it would be possible remove the 2 upper bolts out without taking the disc out the two lower, maybe. This thing is heavy. I am glad that I am not putting it back together specially if it was in the truck.
By the way, they are for sale. PM me if you are interested.
Old 08-10-2019, 03:04 PM   #11
HO455
Post Whore
HO455's Avatar
On my GMC the two upper bolts come from through transmission and thread into the bellhousing and the lower ones through the bellhousing and thread into the transmission.
RIP Bob Parks.
Old 08-10-2019, 11:35 PM   #12
Nima
Blue 67
This bell has total of 6 bolts. 4 from inside bell to the block, the two lower one and then two middle/higher ones, and two very top ones from outside of the bell to the block.
Old 08-11-2019, 01:31 AM   #13
RustyPile
RustyPile's Avatar
Smile Re: How to remove bellhousing bolts?!
The OP isn't asking about the transmission to bell housing bolts.. He's asking about the Bell housing to engine block bolts.. However, the information you provided is common to all GM manual transmission mounting bolt configurations.. I've had customers come into my shop wanting me to replace the 2 lower bolts, thinking the bolt heads had broke off..
RustyPile is offline   Reply With Quote
Old 08-11-2019, 03:48 PM   #14
HO455
Post Whore
HO455's Avatar
Dhoo! My bad!
RIP Bob Parks.
