08-09-2019, 11:21 AM | #1 |
Extra? Shifter hole
What would have been here? Not the stomp starter hole.
08-09-2019, 11:44 AM | #2 |
Re: Extra? Shifter hole
two speed rear shifter, or sometimes an e brake.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
08-09-2019, 01:01 PM | #3 |
Post Whore
Russ is probably right.......but do you not have a pic of what your asking?
08-09-2019, 04:59 PM | #4 |
Photos help but if the trans hump is off a 4000 series the kind of slotted hole to the right of the shifter hole is for the hand brake lever. if i is not to the right of the shifter it might be for some sort of two speed.
08-09-2019, 08:28 PM | #5 |
Could it be for a brownie shifter?
Back in the old days trucks often had two shifters - a main box plus an auxiliary box, or "brownie." When I learned to drive truck it was with a 5-and-4 transmission: 5-speed main box plus 4-speed brownie for a total of 20 forward gears.
1951 Chevy Panel Truck |
08-10-2019, 06:15 AM | #6 |
If you've found the truck I had as a teenager the extra hole is for reverse. I installed a 4 speed Saginaw car transmission but I only had a three speed shifter for the top. I installed a separate rod to engage reverse by shifting into Neutral then pushing the rod down to get reverse.
08-10-2019, 10:59 AM | #7 |
I thought I posted a pic. It is a pop riveted patch. On s factory raised hump. I have no reason to believe trans has been changed. However a 283 has been installed. Along with the bellhousing.
08-10-2019, 12:58 PM | #8 |
Pic attempt #3.
08-10-2019, 02:28 PM | #9 |
handbrake, found on bigger trucks.
08-10-2019, 02:33 PM | #10 |
Agreed.
I'm also noticing that someone took tie to try and make a decent looking patch, especially for a riveted piece. |
08-10-2019, 03:14 PM | #11 |
Apparently someone put hand brake on then it got removed? This fits with the theory of this truck having been a municipal or county truck. ..
Seems to have had a topper on it slot in gate for latch and pull handles welded to gate "Posts' on bumper made from jack hammer bits. Possibly to hold road cones. |
08-10-2019, 11:25 PM | #12 |
Those handbrakes were also on 47 3100's with 3 and 4 speeds. They didn't go to the foot brake until 48 on half and 3/4 ton.
08-12-2019, 10:23 AM | #13 |
The '49 3600 I used to have had a foot pedal parking brake. Both my '56 3600 and '58 36 Apache had the hand brakes.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
