Bed wood sketch
A bit back when i was searching for bed wood replacement i found a thread or post that had what looked like a hand drawn sketch of the measurements for the bed wood groove that the metal bolts down onto. Now i cant find it....anyone have it that can post? Was super easy for me to understand.
Thanks |
![]() Join Date: Oct 2012
Re: Bed wood sketch
Re: Bed wood sketch
Ive seen that one but was looking for another. I guess that one will have to do. Thnx
![]() Join Date: Aug 2010
Re: Bed wood sketch
I actually just finished re-doing the wood in my '62 C20, and could've used that info from GMC Pauls ahead of time. Looking at the dimensions stated there, they are good numbers. All of it.
I milled my own wood, totally from scratch by measuring factory boards from other trucks. That, and referencing Mar-K's info from their website, I got what I thought was exact info. My bed now looks great, but it's a bit tight with not much room for wood growth with moisture changes. I'm a bit concerned it's going to behave badly if it can't move enough seasonally. So, use the info from GMC Pauls, you'll be happy you did. I just wish I would've done that a month ago. |
Moderator
![]() Join Date: Dec 2012
Re: Bed wood sketch
I've done two beds from scratch using the GMCPauls bed info.
Re: Bed wood sketch
I found the picture I was looking for. Was in the gmc forums thought I would pass it along for those that prefer simple pictures like myself. I will use this as well as the link previously posted to get my bed done.
Moderator
![]() ![]() Join Date: Aug 2011
Re: Bed wood sketch
The link that was posted had this on that page(you didnt like it?):
Dimensions A. 3/4" (board thickness) B. 1/4" C. 3/16" D. 7/16" E. 1/8" ![]()
Re: Bed wood sketch
Its not a matter of not liking it. Is just easier for me to understand this way i guess. Lol i will be using both when i start milling the wood.
Re: Bed wood sketch
I was just looking at the board dimensions and getting my shopping list together to head to the lumber yard and came across this question. On the chart from gmcpauls is says the you would need 2 - 6 3/8 boards for in front and behind the wheel well per side. Is that a typo? That would be a super long bed if that’s the case. Any info from you guys that have already did your wood?
#13 |
#14 | |
Re: Bed wood sketch
![]() Last edited by jdl71; 08-18-2019 at 10:47 AM. |
#15 |
Re: Bed wood sketch
This was my list for the lumberyard. Just went yesterday. I haven't cut it and installed yet, so use at your own risk.
![]() 1x8-8 (2) 1x8-10 (6) 1x6-10 (2) 10 boards total and it was less than $100 for it all. |
#16 | |
Re: Bed wood sketch
#17 |
Re: Bed wood sketch
It stays inside. My intent is to try to duplicate the factory finish using linseed oil and lamp black, if I can find it. Otherwise I'll probably paint it. I'm not looking to win any trophies really I just need a usable, affordable floor but your point is well taken.
#18 |
Re: Bed wood sketch
The linseed oil and lamp black idea is an old-timey, antiquated one that it seems just won't die. Our beds were painted, plain and simple. Painted with black enamel that fully cures, unlike linseed oil, which does not.
I don't exactly know where that old idea got it's start, but it's origin came well before our generation trucks were assembled. |
#19 | |
Re: Bed wood sketch
#20 | |
![]() Join Date: Feb 2014
Re: Bed wood sketch
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
#22 |
Re: Bed wood sketch
With this thread still going.... any tips on putting the wood in? Start on the side? Middle? Lifting the bed? Any help would be appreciated. I’m going to be using oak. And will be headed to the lumber yard to start prepping it up.
#23 |
Re: Bed wood sketch
#24 |
Re: Bed wood sketch
Maybe I'm the only one but I used GMC Pauls dimensions and came up short. All the boards were just a tad too narrow. So I placed them where I thought they should be and drilled new holes in the cross braces and then made two wider boards to put down the center. This in a '60 short wide box.
#25 |
Re: Bed wood sketch
Here's my experience, some of this is obvious and some of it might not be the best approach ...
- Fix up the tubs if they need it while they're off. I coated the insides with bed liner. Time permitting, clean or paint the frame, replace trailing arms and/or bushings, check wire harness, etc. - Bed bolt kits don't always include the hidden bolts for the wheel tubs nor the bed frame bolts, in case you need them, too - Install wood with the bed off if possible, it provides easier access and no working on your back - Don't worry if the wood seems a little long when you put it in, just gently push into place and things will fall together - I worked from the middle out and prairie dogged in and out of the gaps putting nuts and bolts into place - Confirm the boards with the frame bolt holes are facing the right direction and on the proper sides - Don't crank down the bolts until everything is installed, just a loose fit until it's all together - The bed sill nuts and bolts are a pain. Put a weight on the bolt head, fumble a washer and lock washer onto the bolt. In the other hand, have the nut in a deep socket (or short socket with an extension) with some paper or piece of rag in it so the bolt sits a little proud. Makes getting the nut aligned and onto the threads a lot easier - Don't pre-drill the bed side and wheel tub holes into the wood, put things in position, center punch, then carefully drill the wood while it's in place - I had 2 different size bolts for the install and no instructions. The only place it got weird was where the bed strips, the bed sides, and the wheel tubs all meet. Working from the middle out, it was easy to figure out which size went where due to the few remaining bolts - Confirm the wheel tub is hooked under the bedside before installing and tightening the hidden bolts. I put a little anti-seize on these threads - Once things are together and you're happy, measure corner to corner and square up the bed - Once squared, I tightened down everything. When done, every bolt got another 1/4 turn to confirm it was tight and none were missing - With things tightened down, aligning the frame bolts was a little bit of a choir, however, the thought of tighten all the bolts up with the bed on the frame sent shivers down my spine. A little anti-seize on the frame bolts can't hurt - Place the rubber bed pads in place after the bed is on, push the bed up and slide into place, use a screw driver or punch to align - Put painters tape along the length of the gap where the tailgate trunnions bolt on so the paint doesn't get scratched up installing the tailgate - Crack open a beer and admire your work The one mistake I made was putting the bed on with the rear bumper in place, should have left it off. Also, should have replaced cab corners while the bed was off, but that's another project for another day – hence the anti-seize on the frame bolts. Would like to hear others experience doing this in case I have to do it again one of these days.
My truck ain't dead, it just smells funny. |
