![]() Join Date: Nov 2012
Hinge rebuilders...?
Does anyone on here know anyone to whom I can send my door hinges to be rebuilt? I do not have the time, or equipment to do it myself, and I need to have this done to assist in me properly reassembling my 67 GMC's front end.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
Post Whore
![]() Join Date: Feb 2016
Re: Hinge rebuilders...?
I recommend looking for a local machine shop. I don't know of any rebuilders since repops are available.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#3 | |
I'm not sure I trust those repops though. I would rather rebuild and oem part than buy cheap repops if I can avoid it.
Yep, OEM door hinges are rebuildable, so no reason to buy repros for worn hinge pins
Post Whore
![]() Join Date: Jul 2016
I can rebuild a set and ship them to you. Sending you a PM now.
If anybody else need some let me know. They can be difficult to get the pins out without an air hammer and a great vise. I a So sand the surfaces where the bushing ride on a belt sander as those are usually worn, pitted, etc. |
![]() Join Date: Dec 2009
HBTS
Here is a few Pictures of what I have in progress. These are the jigs I use to press the pins out. Thanks for the PM today. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Willie at Wilson Antique Car Parts in Virginia.
His website is hoodhingerepair.com Expensive, but a great hinge is critical to all of the gaps to the rockers, fenders, and bedsides. Actually found him through forum members who have used him to rebuild hood hinges and recommend him. He is doing my door hinges right now. Talked to him 3 times on the phone for hood hinges and door hinges. Reviewed his processes, steps that he does. He uses new GM hinge pins and Oilite oil impregnated bronze, like the originals. Presses the pins and bushings into the hinges. His only business is hood and door hinge rebuilding. Does a lot of work for vintage restoration companies. The one negative is lead time. He is out 3 weeks now. Terry |
![]() Join Date: Dec 2013
There's no need to send them out if you have a vise / hammer and visegrips . manes truck parts has the hinge pins with bronze bushings The pins are a little long just measure and trim to length . Easy Peasy . Less than an hour to rebuild all 4 .
![]() https://www.manestruckparts.com/stor...&Category_ID=7
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Grumpy,
Yep, that is another option I seriously considered. Saw your post from you on it while I was considering the options. Then looked at the Manes parts. Are the bronze bushings from manes oil impregnated bronze bushings, like the OEM ones? Terry |
FYI. The oil impregnated bushings are critical. They are sintered powder metal bronze bushings that are then impregnated with oil. The bushing is then 20% oil by volume.
The quality control of the powder metal parts is also critical. They are manufactured/[pressed to a uniform built in porosity to hold the oil. Used to buy ![]() |
sorry about the emoji in the last post. Fat fingered. lol.
#13 | |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#14 |
Tony,
Have you had Willie at hoodhingerepair do just hood hinges for you, or have you had him also do door hinges? On the powder coat he does media blast so maybe he is not using a good of powder coat paint. Not all of the powder coat paints are good quality. There is only one sand blaster and powder coater here that I trust his powder coat paint. Jeff, the vintage car refinisher and painter who will paint my Jimmy, actually has tested the powder coat paints of the players in this area. He has been painting vintage cars and trucks for over 35 years. Even better, a friend of his who retired from one of the main paint companies, showed him how to test specifically powder coat paint. Just like regular paint, but had not even though it on powder coat paint, until Jeff educated me. So much to learn!!! |
#15 | |
On a side, some opinions are don't powder coat springs. In fact, I was told do not PC coil springs. I had em PCd anyway. A guy well-versed in finishes told me PC is a great way to go, because PC flexes.
#16 |
Tony,
Thanks for your clarification on the powder coat on your hinges. Appreciated. Terry |
#17 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Had Willie do my hood hinges 3/4 years ago. I sent then to him he did his thing and sent them back. Hood opens and closes like butter and because the hinges work the way they are supposed to the hood alignment on my truck is super.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#18 |
Old member
Willie did mine and they are great he knows his hinges and how to coat them.
He is the best in the buisness, that doesn't mean he is 100% correct though and yes I'm sure he has mistakes made but I bet he make it right if given the chance. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#19 |
I got my newly rebuilt hinges from randy500! They are GREAT! I have one side installed, and when I am off work and my son can assist again, I will install the right-side ones.
Randy500 has a post in which he offers hinge rebuild service, and I give him two thumbs up! ![]()
#20 | |
I have a set for sale on the parts forum right now if someone needs a set. |
