08-10-2019, 07:11 PM | #1 |
WTB antenna part
I’m looking an original telescoping antenna part. It’s the one that receives the antenna wire and screws onto the above cowl bezel. See pictures
08-10-2019, 08:07 PM | #2 |
Re: WTB antenna part
I have this one.
08-10-2019, 10:29 PM | #3 |
I appreciate the pictures but I don’t think that is the one I’m looking for
08-10-2019, 11:59 PM | #4 |
Im wondering how your going to attach the antenna lead if you find the body.
08-11-2019, 01:04 AM | #5 |
I’m not following. Complete antenna rookie over here. My old antenna wire plugged directly into what I have pictured. I tried replacing my damaged telescoping antenna. It snapped off and then I ruined the part you see in the picture trying to remove the remains. I was talking with another board member and he said it didn’t look original. What are you thoughts?
08-11-2019, 09:11 AM | #6 |
The gold part looks like original the silver part i dont recognize.
I feel like i have seen an antenna where the lead connects to the bottom, just not on one of these trucks. Post a pic of the top and bottom along with the other antenna parts. |
08-11-2019, 09:20 AM | #7 |
Looks like 68 corvette used that type of antenna
https://www.mamotorworks.com/Corvett...-mast-601178-1 |
08-11-2019, 09:35 AM | #8 |
That looks to be right on!!! Not sure how you found that!! I’m going to order it. If it not the right one I can always return it.
08-11-2019, 09:46 AM | #9 |
Here are the pictures
08-11-2019, 09:50 AM | #10 |
I think you can get a stock antenna and if you want use your above cowl hardware. That antenna would probably clean up with some WD40. I had just pulled it out of a box and took the picture.
08-11-2019, 09:53 AM | #11 |
08-11-2019, 10:07 AM | #12 |
Carpe manana
OEM pickup telescoping antenna masts affix to the base by a use of a female threaded collar - the crown piece doesn’t hold the mast in place nor does the mast have threads.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-11-2019, 10:10 AM | #13 |
I have seen that type of antenna before on these trucks but not with the removable wire. I usually just have 71-2 trucks and they have the one like deadhead posted. I guess that body will fix your problem and your upper parts look stock.
08-11-2019, 10:43 AM | #14 |
Mine is off my 1970 truck. Did they make different antennas for different years?
08-11-2019, 12:11 PM | #15 |
Im not sure of the antenna year differences but yours seems correct for 70.
08-11-2019, 03:18 PM | #16 |
Carpe manana
Would be great to learn if so. We’ve gone around with whether or not fm had a fixed mast also.
08-11-2019, 05:03 PM | #17 | ||
I can't answer the question of fixed vs. telescoping antennas for AM/FM radios' However, I do recall owning a car (probably a '69 Olds or '65 Impala SS), which had instructions in the owner's manual stating that the antenna should be adjusted to 31" for best FM reception. |
08-11-2019, 05:16 PM | #18 |
Additionally, the base Randy linked in post 7 does look similar to my base. The antenna lead in the link below also appears to be the same as mine. Not sure the length would be the same though.
https://www.mamotorworks.com/Corvett...cable-601184-1 |
08-11-2019, 06:58 PM | #19 |
We found this really interesting. Thank you for all the additional information.
08-11-2019, 07:29 PM | #20 |
I think you'll be fine if you order the part Randy posted as long as the end of your antenna lead looks like the one I posted a link to. The antenna should screw into the end shown at the top of the 1st picture you posted where the hexagonal metal part is. The lead should slip over the bottom end in the same picture.
08-11-2019, 10:32 PM | #21 |
Part is ordered. I’ll let everybody know how it fits
08-17-2019, 02:41 PM | #22 | |
I suspect this is too late and beyond the scope of this thread, but maybe someone will find it useful in the future. Realize this is from a '69. I believe '70s used the same style antenna. Not sure when they switched to the one Pete posted, but I believe it was '71 or '72. The picture below shows all the parts related to the original antenna from my '69 except the firewall grommet. The parts on the left go above the cowl. Those on the right go below the cowl. |
