Custom Belt question
If I'm not running an A/C setup, where do I go or can go to get a custom belt for my application??
Re: Custom Belt question
A gen IV 5.3 vortec engine has a completely separate belt just for the AC compressor. It can be deleted without affecting the rest of the accessory drive.
I thought the same applied to other LS engines. Maybe not.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
Post Whore
![]() ![]() Join Date: May 2015
All 4 of mine have seperate ac belts
If I'm not using power steering, do I still need the pully installed to make the belt work?
Or can the belt be re-routed without the pully and still be fine? |
Post Whore
That may be a diff issue....most I've seen without the psp have the aftermarket accessory drive system...looking at mine I dont see a good way to eliminate the psp with a stock drive setup...the belt comes off the wp and goes around psp and then to alt....theres no direct route from wp to alt without psp...
I know reaper has his setup without psp... but with aftermarket drive on one..
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 08-14-2019 at 11:19 PM. |
![]() Join Date: Mar 2011
This is the set-up my son Mark (reaper71) did on a 49 Dodge with LS, no power steering and no AC, maybe this is what you need...Jim
P.S. Sorry last pic is unclear. Size is 13/16" X 75 5/8" OC...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 08-11-2019 at 11:58 PM. |
Thats what I thought, I got the 76 inch and it was to big by an inch or two...so I picked up a 72" incher and ill let you know if that works?
Thoughts on why the sizes would be different? Mines an LS 6.0 |
M-10, 1.50 thread, 160 mm, 82 1/2 belt 5060824 (dayco), 900027A pulley. I used and old tensioner pulley., Cut then little nipple off for a bushing and the above parts
Not trying to start a controversy here, but after looking at the two belt configurations, I noticed the waterpump spin direction on the Reaper truck is opposite of the normal rotation. Can the pump work in both directions?
Post Whore
its the same lee
![]() ![]() Last edited by LeesTruk; 08-15-2019 at 11:31 AM. |
Any pulley that contacts the ribbed side of the belt is turning the same direction as the crank pulley.
Any pulley that is operated by the smooth side is turning the opposite direction.
