Old 08-14-2019, 12:09 AM   #1
HONDAWASAKI
Exhausted
What are you guys doing with your exhaust systems? I'm stuck looking at pages of c10 exhaust kits wondering which ones are junk, which ones are acceptable, or even if a kit is the right way to go. Maybe a builders bend pack, and mufflers from summit? Or just take the damn truck to master muffler. If anyone has installed pics, it would help out tremendously. Thanks.
'67 C10 shortie.
HONDAWASAKI is offline   Reply With Quote
Old 08-14-2019, 08:46 AM   #2
68Stepbed
68Stepbed's Avatar
Re: Exhausted
I had Rusbuilt make my exhaust from a stainless builder's kit. Of course, My TCI Engineering suspension made a few hurdles that required such a setup. Not to mention the fact my engine breathes soooo much better with the mandrel bends compared to the exhaust shop bends. He also used Deadend Garage crossmember cutouts to run it inside the framerails. As you can see from two of the photos, the exhaust doesn't hang below the frame anywhere.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-14-2019, 09:24 AM   #3
toddoky
Re: Exhausted
You may be more likely to determine the best route to take by creating a list of qualities and characteristics you want the end result to possess. Do you have aftermarket parts (i.e. lowered suspension, frame mounted fuel tank, wide rear wheels/tires etc...) on your truck that you need your exhaust to be able accommodate? Do you want a stainless steel system and if so do you want it to be 304SS or would 409SS be acceptable to you? Are mandrel bends a requirement for you, or would you be OK with muffler shop produced compression bent tubes? Answering these types of questions for yourself and posting them here will net you some more comprehensive answers to your question I believe.
toddoky is offline   Reply With Quote
Old 08-16-2019, 10:03 AM   #4
e015475
e015475's Avatar
Re: Exhausted
Build one.
This is one for an AD truck with an IRS, so the exhaust mounts under the diff. 2.5" mild steel mandrel bends from Columbia River Mandrel Bends and inexpensive Thrush turbo mufflers from Summit. About $200 in material. Double this if you want stainless.
On the floor ready to install
Installed
e015475 is offline   Reply With Quote
Old 08-19-2019, 03:18 PM   #5
HONDAWASAKI
Re: Exhausted
Beautiful trucks, and Beautiful exhaust systems. It gives me ideas. I appreciate it.
'67 C10 shortie.
Old 08-22-2019, 03:27 AM   #6
Gregski
Post Whore
Gregski's Avatar
Re: Exhausted
Originally Posted by 68Stepbed View Post
I had Rusbuilt make my exhaust from a stainless builder's kit. Of course, My TCI Engineering suspension made a few hurdles that required such a setup. Not to mention the fact my engine breathes soooo much better with the mandrel bends compared to the exhaust shop bends...
that's not an exhaust system that's art! thank you for sharing
Gregski is offline   Reply With Quote
Old 08-29-2019, 03:17 PM   #7
tinydb84
tinydb84's Avatar
Re: Exhausted
Unless you are doing a swap that uses a kit and has recommended parts I would have one made. I did this one on my brother's Nova for $40 in scrap stainless and a set of Blackwidow mufflers. Sounds great.
Here is my custom exhaust on my truck. I used one of those spinny muffler things.
David
Instagram: myfabguy
Old 09-02-2019, 10:57 PM   #8
solidaxel
solidaxel's Avatar
Re: Exhausted
Corvette IRS rear exhaust
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-14-2019, 06:26 PM   #9
HONDAWASAKI
Re: Exhausted
I ended up getting a thrush kit from summit racing. I had to modify it a bit to fit my headers, but overall I am really happy with the note, and fitment. Thanks to everyone who replied, your trucks are works of art.
'67 C10 shortie.
Old 09-14-2019, 06:27 PM   #10
HONDAWASAKI
Re: Exhausted
Obligatory engine pic.
'67 C10 shortie.
Old 09-15-2019, 10:47 AM   #11
Gregski
Post Whore
Gregski's Avatar
Re: Exhausted
not sure of your desired level of doneness if you are the stainless steel everything needs to be shinny and tig welded, or if you are like me and want it to be strong and sound amazeballz, so I went to Pick N Pull and yanked a bunch of Silverado 2500 3/4 ton truck intermediate pipes and two sets of Suburban over the axle tail pipes (yes I had to flip one to make it exit on the driver side) lots of cuts, lots of welding, lots of work, but man it sounds so good, oh running duals all the way with Magnaflow mufflers, no headers (just Holley 2.5" cast iron manifolds) no X pipe no H pipe (too old for that nonsense, ha ha)
