Old 08-15-2019, 10:43 PM   #1
mygmctruck1
Center A/C vent
How may I ask do you attach the center vent A/C grill and the box to get the air to it ?
mygmctruck1 is offline   Reply With Quote
Old 08-15-2019, 10:57 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: Center A/C vent
The Grill has two posts that go through the box, then the hose attaches to the box.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 08-15-2019, 10:58 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Center A/C vent
There are 2 pieces to the center vent. The part you see on the dash and then the part inside the dash. The part you see has 2 studs made into it that go through holes on the plastic part behind the dash with nuts which sandwich the dash between them. Then the two hoses that connect it to the inside dash box on the passenger side of the truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-15-2019, 11:05 PM   #4
mygmctruck1
Re: Center A/C vent
Thank you , my parts did not have the 2 studs or any instructions .i can make my own studs .
Old 08-15-2019, 11:20 PM   #5
Andy4639
Old member
Andy4639's Avatar
I think they are 1/4" 20 studs. Some all thread rod should do the trick.
Old 08-16-2019, 08:37 AM   #6
Jim Boy
Smile Re: Center A/C vent
I found with mine that if I balanced on my head and placed both feet into the rear corners of the cab it would leave my hands free to do the work. The system had to be designed by someone wearing a shirt and tie.. Good luck.
Jim Boy is offline   Reply With Quote
Old 08-16-2019, 10:13 AM   #7
mygmctruck1
Re: Center A/C vent
A shirt and tie , YES . Try working under the dash of a 69 mustang , with air and all those Vacume actuators .
Old 08-16-2019, 12:42 PM   #8
Astro-Balls
Re: Center A/C vent
Just did the AC and Heater core in a 69 Mustang, the whole freeakin Dash has to come out, and I mean everything..
Old 08-16-2019, 03:20 PM   #9
mygmctruck1
Re: Center A/C vent
Yep, I had to do the same thing and while I was at it cleaned the vac motors and tested . reviewed the wiring ,
It took me 3 hrs and tons of pics to dissemble and 3 days to reassemble.
It's a big PITA for sure !
Old 08-16-2019, 08:24 PM   #10
Jim Boy
The biggest problem is the word FORD. With the Chevy's there is no room for actuators, it's more of a balancing act problem. Mine needs a shot of R12 but I can do that standing up. Have a good one eh.
