12-02-2003, 02:06 AM | #1 |
"Ochre Ogre"
How long will it take me? 4x4front repair.
It sounds like the needle bearings have evaporated from the front RH u-joint. This is in my 72 3/4ton 4x4 plow truck. The lack of snow at the moment means I should get it fixed now rather than when I need to use it to push snow. How much time would or should this take for a first timer.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
12-02-2003, 02:25 AM | #2 |
Registered truck nut
It's not that bad. Took me a day to do both sides and I'm not speedy or an expert. This was my first time. Check out those wheel bearing real close. If they're original, now would be a good time to replace them and the races
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
12-02-2003, 03:06 PM | #3 |
I agree, it won't be that bad. You might want to get a socket for the spindle nuts. Also make sure the axle tubes are clean before reinstalling the axles or you will push a bunch of sludge into the differential.
Eric 1969 K20, 465/205 package |
