Old 08-16-2019, 06:45 PM   #1
Electrix
Gas filler neck install - quick and dry
I got the idea to install the grommet with a string after installing a windshield in my other truck.
You need to hold the grommet from the outside and guide it along the curvature of the cab as you pull the string. I installed this one in about 1 or 2 minutes.
Electrix is offline   Reply With Quote
Old 08-16-2019, 07:43 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: Gas filler neck install - quick and dry
try doing it with the filler pipe in place.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 08-16-2019, 09:49 PM   #3
Mike C
Mike C's Avatar
Yup. That's going to be the challenge for us with the Jimmy we are painting with the filler installed. It was hard enough getting the old one out!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-16-2019, 10:49 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I'm curious to see how that would work too.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-16-2019, 10:54 PM   #5
Astro-Balls
If you do a search, lots of guys have done it, chose the good quality rubber grommet to start.
Old 08-16-2019, 11:26 PM   #6
Electrix
I would suggest you remove the neck to get full paint coverage under the neck's mounting flange. Since painting is an attempt at corrosion resistance you want to cover all of it. It's on'y a few screws and some hose clamps. On a Blazer/Jimmy I would remove the neck first, remove grommet, paint, install grommet, install neck. Same as a truck, just a neck rather than the whole tank.
Old 08-16-2019, 11:50 PM   #7
Sheepdip
Sheepdip's Avatar
Just replaced mine last week, had it in the glove box for a good 6 months or so. Used a razor knife to get the old dried up one out, and after several attempts and some very choice words I finally decided I was using too much lube since it would pop out as fast as I could push it in.
I wiped it down, used minimal lube, and it went in, not easy but got er done.,
And yes buy a good one... I think mine came from GMC Paul's the good one made in U.S.A.
Sheepdip is offline   Reply With Quote
