Old 08-17-2019, 02:06 PM   #1
Astro-Balls
Astro-Balls's Avatar
Vacuum Diagram
is this the correct vacuum diagram for a '68 BBC AC PB?
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 08-17-2019, 04:48 PM   #2
Astro-Balls
Re: Vacuum Diagram
The Control Head Vacuum Switch on my truck has three ports, Need to know what goes where.... Help..
Old 08-17-2019, 06:08 PM   #3
Astro-Balls
Re: Vacuum Diagram
The Three Vacuum nipples on the Control Head Switch, Is one supposed o be plugged? anyone have a diagram of where the hoses go?
Old 08-17-2019, 06:44 PM   #4
dmjlambert
dmjlambert's Avatar
Re: Vacuum Diagram
The 3 port controller has a different diagram. But the water valve needs to be the type that is water open with vacuum applied. If you have the water valve that closes with vacuum applied, then you could probably use the diagram you posted and cap off the unused port on your controller. You would have to experiment to figure out which port to cap.
dmjlambert is offline   Reply With Quote
Old 08-18-2019, 12:38 AM   #5
Astro-Balls
Re: Vacuum Diagram
Thanks very much.
