Old 08-19-2019, 03:10 PM   #1
96blazr
96blazr's Avatar
1968 C10 Front Alginment, Toe and camber Specs
Good day Everyone. I'm in need of Toe-in/out, Camber and total alignment Specs for my 1968 C10 1/2 SWB, please. If anyone has a link or a site to access, please let me know.
Thanks in Advance.
1968 SWB.
GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators.
Remember, no matter where you go,
There you are.
Gary
96blazr is offline   Reply With Quote
Old 08-19-2019, 03:59 PM   #2
Wrenchbender Ret
Re: 1968 C10 Front Alginment, Toe and camber Specs
Ive always had the best handling with normal tire wear with these specs.
1 degree pos. caster. 1/4 degree neg. camber & 1/16 in. toe-in.
Wrenchbender Ret is offline   Reply With Quote
Old 08-20-2019, 07:27 AM   #3
96blazr
96blazr's Avatar
Thank you Wrenchbender.
1968 SWB.
There you are.
Gary
Old 08-20-2019, 10:43 AM   #4
68 P.O.S.
Read this thread. He did a great job on getting us good numbers to use. http://67-72chevytrucks.com/vboard/s...d.php?t=582187
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-20-2019, 11:25 AM   #5
96blazr
96blazr's Avatar
Thank you 68 P.O.S.
1968 SWB.
There you are.
Gary
Old 08-20-2019, 01:38 PM   #6
mr48chev
mr48chev's Avatar
Wrench bender hit it pretty close. The stuff in the thread that 68 P.O.S.linked that those guys are throwing around is strictly for trucks that are driven on the auto cross courses at Good guys and those specs (2 neg is OUT OF ALIGNMENT) will eat your tires off the truck before you get to the first event that is 50 miles away. You cannot runs specs that are for racing on the street and expect your spendy tires to last.
Back when tires were narrower I set these trucks up with 1/2 degree + camber on the left, 1/4 degree + on the right an 1 degree + caster with 1/8 toe in. The 1/4 difference in camber compensates for the crown in the road and may have to be tweaked a tad if you live in an area that has more crown on the roads or a dry area like some parts of Arizona or New Mexico that have less crown on the roads.
I would not get past the 1/4 neg that wrenchbender suggested no matter what the self styled experts throw out. On the other hand I wouldn't get past 1/2 + either. You get too far either way and the weight of the front end is carried on either the inner half or outer half of the tread causing the tires to wear uneven and wear out far too soon costing you a bunch of money.
My ongoing truck projects:
Old 08-20-2019, 04:10 PM   #7
68 P.O.S.
Not sure where you're getting that from, but the thread I posted from BEMERDOC has nothing to do with setting your truck up for auto crossing and racing applications. It's about improving upon the short comings of the stock specs to get a better, modern alignment since the stock specs are antiquated and not performance friendly. Were the stock specs even meant for radial tires? Wow, calling a 20 year BMW master tech a "self styled expert" after he went through the trouble of testing these setups to try and help us board members out...truly a douche bag move. Bravo sir, bravo!
96blazr, stick with the numbers in the thread I posted and you're truck's alignment will be better than ever. BMERDOC has a couple of good threads on the subject, so check those out as well for real world results and to get more info on this. Let us know if you need anymore help and we can get you squared away.
Old 08-21-2019, 09:40 AM   #8
96blazr
96blazr's Avatar
Okay, thanks. yeah, I read that response and was totally confused, cause I never mentioned racing and you never mentioned racing and all I'm asking for is, more or less, stock Specs.
Now, my truck has been lowered 2-inches all around and I just installed an ECE Anti-sway bar, if that matters.
No worries 68POS, I'll be using your specs.
1968 SWB.
There you are.
Gary
Old 08-21-2019, 10:51 AM   #9
68 P.O.S.
How did you lower your truck, springs only? Since you're getting it aligned anyway, the springs won't matter. The sway bar doesn't affect alignment either. Good move adding it though, it helps out the handling quite a bit. I've added a rear sway bar on mine and it handles fantastic.
Very nice truck by the way!
Old 08-21-2019, 11:15 AM   #10
96blazr
96blazr's Avatar
Ok, thanks. I was wondering if lowering it at all would affect the alignment settings.
Yes. 2-inch lowering Springs only with Gas Shocks from ECE. And the Sway-bar is from ECE too. None of that CPP crap for this kid. I lowered it 2-inches cause I still want it to LOOK like a truck, but lower the center-of-gravity and make it handle at little better.
Cause as you know, I'll be running on those auto cross courses at Good-Guys and I need all the handling I get!!
1968 SWB.
There you are.
Gary
Old 08-21-2019, 11:44 AM   #11
68 P.O.S.
When you lower with springs only, it does change the alignment so you would have to realign it after the install. Since you've already got them in, it doesn't matter. Lowering spindles on the other hand do not affect the alignment geometry at all.
Good job going with ECE for your parts. Top notch company, can't say enough about them. All of my suspension parts come from them too. I normally stay away from CPP as well, although I do have their rear sway bar. Make sure you add that rear sway bar for those road courses there buddy
Old 08-21-2019, 12:19 PM   #12
KMC3420
KMC3420's Avatar
I have a question on lowering and hope i don’t offend the OP. For the rear I plan on dropping mine 5 inches total. Is it ideal to get your drop from 5” drop springs or to utilize a 4” drop spring and 1” lowering block?
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 08-21-2019, 12:24 PM   #13
96blazr
96blazr's Avatar
You're not "offending" me at all, but if it were me, I'd start a new thread and get a better chance of reaching a wider audience and therefore more answers. Not a sermon, just a thought.
1968 SWB.
There you are.
Gary
Old 08-21-2019, 12:33 PM   #14
68 P.O.S.
Honestly, I don't know if it really matters, claims can be made for either way. I've heard people here say blocks are better for retaining spring rates for towing and hauling applications. At the same token, I've also seen people on here who claim to have 6" lowering springs and have no issue towing/hauling. I personally prefer springs only, but again, does it really matter? I do know that with blocks you can run into interference with smaller rims, like 15's, rubbing. Hopefully others will chime in with their expertise.
Old 08-21-2019, 12:41 PM   #15
KMC3420
KMC3420's Avatar
Thanks 96blazr and 68POS. I just wanted to get an opinion on it. What I have mostly read is concerning spring rates. I also read the issue with 15” wheels and being too low if you get a flat. I just wanted to know what science was involved but agree there are valid arguments for both sides. I read through the make it handle thread but didn’t make it all the way through. I didn’t see much on the topic, but I’m sure it’s in there. Thanks fellas.
Keagan
Old 08-21-2019, 03:38 PM   #16
HO455
Post Whore
HO455's Avatar
First off nice truck!
Second is if your driving the truck a lot you might look into doing a modification to allow more caster. Tons of info on this on the forum. I did my daily driver Burban along with an alignment similar to BMWDOC's thread 16k miles ago with great results.
Third is with amount you have lowered the truck you should have no alignment issues or bump steer issues.
And did I mention what a nice truck you have?
RIP Bob Parks.
Old 08-22-2019, 07:42 AM   #17
96blazr
96blazr's Avatar
No, I don't think you mentioned it
Thank you HO455, I appreciate it.
I don't drive it "A lot" per say. Just on rainless weekends to Shows, Cars & Coffee and Parades(I'm a Shriner). Thanks for the input and info.
1968 SWB.
There you are.
Gary
