led taillights, would you get them again?
i almost ordered them again but im not sure yet, i know ruemster dissapeared and a few people had problems with the lights, i guess i will have to get them through ece but first, what else is needed? it says electronic flasher, anyone have a part #? would you buy them again or stick a couple 99 cent bulbs in and be done?
its all about the +6 inches
Well, mine are kinda cheap and I love them. I'm trying to figure how to replace other lights with LEDs.
The electronic flasher would be easy, just go to NAPA and ask for a 2 plrong electronic flasher. |
67-72 Addict!
EL12 I think.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I would get them. They are no longer made by hand. The problems people were having were related to the connections.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I have them and would get them again...Joel told me it was only the first ones tehy made that needed the electronic flasher but they're only a few dollars so it cant hurt.
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
Active Member
![]() Join Date: Feb 2000
I got mine from Reumster (early model) had some problems, but he made good on them. The newer ones are great and I would do it again. They are really bright and really red.
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
What does a set of the newer style "mass produced" ones cost anyway? Just curious.
Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
I love doing it topless
what...LED's
are these for the 1157's or what. i have not seen these but would like to. I love LED's. I will be putting them under the bed rails in my blazer for hidden and bright interior lighting.
In my stratus I have blue ones in my headlight to light up the housing a soft but erie blue and just did this to the third brake light.
Mikey "If you can read this, thank a teacher; If you are reading it in English, thank a soldier." ![]() |
71 DELUX
mmgoodie,
I think someone is trying to get out of your trunk! I've seen these LED plug in replacement cluster bulbs in the Stylin Concepts catalogue and the local Pep Boys, think they run about $12-16 buck each. Saw some yesterday on a 65 SWB, and they were BRIGHT! |
well...
does anyone have a pic of this
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Someone also post a link to the JEG'S site that hd em for 100$$ I think it was longhorn man..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#13 |
Yeah, turned out they are not the same as Reumster was selling...but stilla decent light.
Those plug in leds are junk. (the bulb replacement) |
#14 |
The ECE kit looks pretty good, I might have to add that to my list of upgrades for this winter. Maybe even clear lenses all around... Hmmm...???
#15 |
Old Skool Club
![]() Join Date: Jun 2001
Don't get APC bulbs....they're JUNK!
Try www.ledtronics.com, for some genuinely GOOD LED bulbs to replace 1157's. BUT, you are gonna have to get off of your wallet to do so, to the tune of $48 per bulb. I have them in my '69, and I tried the APC bulbs in the park/turn, but they wouldn't go in but one of the sockets. The rears are great!
So, consider $48 each bulb at www.ledtronics.com, vs. ECE for more LED's and engineered to fit our housings. Food for thought.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#16 |
PROJECT 7DEUCE
CHEVLORAY DO U BY ANY CHANCE HAVE PIC'S???
#17 |
WAL-MART has them for around 8.00 bucks .
2004 Extended cab LS silverado ![]() 2001 Buick Lesabre 1968 Chevy Custom 10 LWB Anniversery model 2008 crew cab lt (rolling on dubs) "The nice part about living in a small town is when you don't know what you're doing, someone else always does" |
#18 |
"Trucks with Class"
![]() Join Date: Jul 2000
I used to sell them for $120, but not sure if I can get more now that ECE tied up the market with their exclusive deal. If you are not careful, the panels will break when you install them...found out the hardway...but I am sure ECE explains that and how to prevent that. I sure hope so.
They are slick...168 individual leds and they light up the entire lens, not just the old bulb area on top. |
#19 |
Mine isn't quite that cool...but it works just the same, and I only spent 50 bucks. http://67-72chevytrucks.com/vboard/s...threadid=72407
#20 |
L.E.D. Tail lights, Baby!
lemme settle a few things, again.
Howdy,
First off, Frank @ Franks Pickem-up parts: Are you still getting the led boards from Dave @ ECE? If not I need to know about it so I can rectify the situation. Yes they can break if you tighten them bown too tight. In order to fix that we have added some hardware to make your lens break befor the LED board does. He is supposed to be selling them to you @ wholesale. If this isn't the case I need to know ASAP!! As far as the electronic flasher. You don't necessarily need them with just the rear taillights. It's when we come out with the front turn signals and you have them both installed is when they are going to be necessary. As far as the exclusive deal with dave @ early classic, it's so exclusive I cannot sell my own lights to anyone other than Dave. But it has been good for us, they have been on the TV show TRUCKS! four times now. Hard to complain about that. I am no longer in business with Ryan Reum. I have decided to move on and do other things, but the warranties are all valid. Her's something else. The first 100 sets we sold that were on the Green circuit boards were built by hand. Either I or another professional assembler assembled the leds and othre parts, and soldered them to the board. The newer ones were soldered by a machine that actually heats up the board a few hundred degrees. With the board that hot, the solder joints are much less brittle. If you have a set that doesn't work right or has some LEDs out, please let me know ASAP so I can take care of it. I don't remember what Dave @ ECE is selling them for off the top of my head, but I am not making a killing. IN all honesty, taking into development costs, I am still somewhat in the hole. We made a whole series of 67-68 front turn signals that we are still trying to get working right. The third brake light Dave has is expensive because of the dual white cargo light LEDs. I think we have to pay over 20x the price for the white LEDs as we do the red ones. I am also going to be getting started on more frint turn signals as well as a circuit that you could plug into your Dome light to have it fade out, after you shut the truck off, and shut the door like so many of the newer vehicles use. I think they are worth it, but I am biased. They do make more of a difference that anything else out there. Plus they are warrantied for as long as you own your truck. Thanks to: Curbstone Mech, and useRc10 for your support.
Prov 3:5-8 "Hook 'em" L.E.D. Taillights for sale NOW!!! If interested, visit: www.earlyclassic.com or our website: www.jmcled.com All 67-72 GM Taillights are on sale untill 5 p.m. on Dec 15th, with Guaranteed Christmas delivery! joel.mcwaters@jmcled.com |
#21 |
"Trucks with Class"
Still selling them!
I had a big run on these after this post and just got resupplied, no problem. I did not see any changes, but may have to look closer. I still add a printed set of instructions/installation tips with the ones I sell.
Price is still $120 + $10 shipping. |
#22 |
67-72 Addict!
jmac05, are you saying Reumster is out of the LED business and you have the company solely?. I stopped trying to contact him after several attempts because he didn't live up to HIS end of a deal we made almost a year ago. Good luck with your company!
#23 |
Frank,
Just let me know if you ever have any trouble. Randy @ D2M was adamant about letting you have the deal you have when we first negotiated with ECE. Any future deals involved with anyone concerned with these classic Chevy models will have you getting the same wholesale as anyone else. 70c10, Uhhh, yes and no. I don't know what was up with Ryan (Reumster). I am supposed to be his business partner but getting ahold of him was like grabbin' a greased snake in a mud pit during a Tsunami. He'd call me or email me when he needed some tail lights or wanted me to fix them for someone. He didn't have his own phone line. I actually laid out the boards with a CAD tool, and helped get them sold by calling prospective customers who could sell them (we are doing mustangs with National Parts Depot). I got called by Dave @ ECE if he had problems or issues. Towards the end, I called to talk to Ryan every night for 12 days straight. I never was able to get a hold of him, eventhough I spoke to someone everytime and told them to please leave a note that his business partner called and I need to hear from him ASAP!!. ![]() ![]() Finally he called me late on a saturday night on a cell phone that crapped out 5 seconds after he said "What's happenin'?" He hasn't called me since. That was five weeks ago, I think. I decided I have other things that are more important in my life right now than having to deal with this. So, I ended my business relationship with him, as of Dec.31, 2003. Ryan has all the files to make all the Chevy lights we did, if he can afford it. Otherwise my interest has been "sold" to D2M. They will be handling this business, just as they have been. If it turns out I want to get back into it, I may. If you have bought from me, or even ryan, and you have problems, you can still contact me for resolutions. If you bought them through ECE, Frank's, or even D2M, They will handle it. You can however, email me questions/comments or if you have a problem, and I will see if I can help you through it, before you have to send them in. It may be something simple. With electronics, you never know... 70c10 , what ever problems you are having let me know and I will take care of it. I have also found out the hard way Ryan doesn't always live up to his end of the deal. It's just ![]() I have a deal on the Table from D2M to actually start a new company that I am the sole employee. I'd be president, V.P. of anything I could think of, my own secretary... I would basically do what I did previously, but I'd have more support from D2M. I am considering it. D2M thinks this could be a great year for this, so we'll see. If I do, I'll let y'all know.
Prov 3:5-8 "Hook 'em" L.E.D. Taillights for sale NOW!!! If interested, visit: www.earlyclassic.com or our website: www.jmcled.com All 67-72 GM Taillights are on sale untill 5 p.m. on Dec 15th, with Guaranteed Christmas delivery! joel.mcwaters@jmcled.com Last edited by Jmac05; 01-09-2004 at 07:00 PM. |
#24 |
Jmac05
Did anyone ever figure out LED's for the stepside lights? Us stepside guys are being left in the dark (pun intended). J/K I tried to use the bulbs at the auto store, but the angle of the bulb (down)makes it impossible to see the light at all!! Have y'all expiremented with the tractor trailer LEDs on the trailers? Please keep us stepsides in mind!!! And good luck with the front parking lights and sidemarker lights. If I could get them all for my stepside as a package deal I probably would!!!
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#25 |
jorgensensc ,
I have an original stepside tail light, the large round one. I guess i haven't done it yet because there really hasn't been a demand for one. I suppose I could finish the design, but unless I build a couple hundred at a time, they are going to be much more expensive than what they need to be. as far as side markers, your best bet is something like the Jam Strait replacements that local auto parts stores may have. It isn't practical for us to do them.
