Old 12-02-2003, 07:15 AM   #1
TIMSPEED
TIMSPEED's Avatar
Anyone ever made their own C-notch?
It doesn't seem like it would be too hard. I already have a set of the bumpstops that you see inside them (the little rubber button head things).
So couldn't I just get a piece of steel in the shape of an L, that's probably like 3"x4" 10" long, and cut out a section, then trace that section on the frame, then cut that section out on the frame, then weld in the plate?
Would this be a bad idea?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 12-02-2003, 11:29 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
If you can fabricate and weld, you can do it. My Blazer and my Cheyenne both have a fabricated C-notch. You need to box the frame on the inside to give proper support...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-02-2003, 12:16 PM   #3
Izzy
Trucker.
Izzy's Avatar
I agree with ken it's easy. A piece of thick wall well pipe and some plate for the inside and you're good.
Step notches are easy too just get some 3/16" or 1/4" plate for the sides and the same for the top/bottom caps. You'll need to have a machine shop break the top/bottom caps unless you have that handy. :read:
Izzy is offline   Reply With Quote
Old 12-02-2003, 04:06 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I have never bought one, so all of them I have made.
The first used Sched 40 6" pipe, the second used a 6" U-channel.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-02-2003, 11:16 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I wonder if the weld will hold on that second one That's a serious bead there
Old 12-02-2003, 11:37 PM   #6
7T7
Regular guy
7T7's Avatar
Get the sawsall out and go for the gusto!
BIG NOTCH!!
1.cut notch out with scissors.....
7T7 is offline   Reply With Quote
Old 12-02-2003, 11:38 PM   #7
7T7
Regular guy
7T7's Avatar
2.glue into place
[url]
Old 12-02-2003, 11:40 PM   #8
7T7
Regular guy
7T7's Avatar
3. paint it your favorite color
Old 12-02-2003, 11:50 PM   #9
98L150
///Relaxed Atmosphere
98L150's Avatar
Here is my 64's step notch
Here is a pic of my 64's step notch that I did. Bending the outer and inner plates to match the frame contour is the only tricky part that I ran into.
98L150 is offline   Reply With Quote
Old 12-03-2003, 12:01 PM   #10
jamis
F.A.S.T. president
jamis's Avatar
It was a pain in the butt to do because of all the diffrent angles.
jamis is offline   Reply With Quote
Old 12-04-2003, 05:09 AM   #11
78chevstepside
78chevstepside's Avatar
Cardboard makes a good template. Make what your going to build out of cardboard first. That way its easy to get the proper angles. Angle finder works great also. then trace it on your steel with soap stone . I bought my c-notch. but a guy could easly go to the store take measuements and build his own. I kinda wish i built my own now. But then again i have built things before that i could buy cheaper then i could make. Or buy one and make a thousand of them and sell them. Looks very nice:7t7 and n2trux bowtie:
78chevstepside is offline   Reply With Quote
Old 12-04-2003, 05:11 AM   #12
78chevstepside
Old 12-10-2003, 09:41 PM   #13
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Driver side...
MrShelley is offline   Reply With Quote
Old 12-10-2003, 09:42 PM   #14
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Passenger side, extended to clear Early Classic extended trailing arm bar/mount (bar removed in photo)
Old 12-10-2003, 11:44 PM   #15
phantom dually
Project92 SWB stepside
phantom dually's Avatar
So are you gonna do it??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 12-15-2003, 09:02 PM   #16
pat
pat's Avatar
Im working on taking my frame apart to try and make a C-notch. I was planning on making one like you can buy and then bolting it in. What all pieces of the frame do you need to take off? There is the one piece that connects the 2 framerails and then the other pieces that Im not sure of...
Also, I have no way right now of lining up the rear end with the frame to find the point where it would bottom out b/c my truck is just the bare frame right now. So, is there a way to find the exact spot to put the notch in so that the axle will settle directly into it?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 12-15-2003, 09:49 PM   #17
98L150
98L150's Avatar
Pat use the wheel base
Pat,
If you have the front suspension still on the truck you can measure the wheel base front he center of the spindle back on the frame. From the center of the spindle to the measured wheek base length would determine on the frame were the center of the rear end would hit the fram and you could use this to mark the center of the notch.
This is just my own opinion of how to do it with out a rearend inteh truck or have another frame already done to reference off of for measurements.
Jeff
Old 12-17-2003, 03:45 PM   #18
pat
pat's Avatar
I would except my truck is only the framerails, everything else is off, the rear end and front suspension are taken off. Any other way?...
Also, what braces will be removed and not put back on?
Old 12-17-2003, 10:58 PM   #19
Slammed67
Progress = 0%
Slammed67's Avatar
If you are fabricating your own notch, I'd recommend bolting the traling arms and rear axle back on the truck to make sure you notch it in the correct spot. I used the bolt-in notch sold by CPP and it gave directions on where to place the notch so there was no guess work.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
