Post Whore
![]() Join Date: Feb 2016
Can you ID this bracket?
I know it is an alternator bracket but what is it off of? If I could find one it looks like it would solve my lack of adjustment range I currently have. (see 2nd photo). The alternator hits the aftermarket valve cover.
Thanks for looking Just to clarify the first photo isn't my truck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 08-24-2019 at 12:25 PM. Reason: Clarification of photo |
Re: Can you ID this bracket?
You sure you want to eliminate the PCV ?
71 C-20 07 Magnum RT AWD |
Post Whore
I have it on the other side.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Jul 2018
Pretty sure that PCV needs to be on the other side to work right. Drivers side is a breath out and other side (passenger side) is a breath in. I may be totally wrong but I believe it works opposite from the way you have it hooked up.
Bracket I don’t know about but why not try a slightly longer belt?
1971 Custom/10 - 350/3 speed, Orange/White roof |
Post Whore
The problem I have with the alternator at this point is that there is very little adjustment range available. The 2nd photo in the 1st post above is with the alternator as far to the water pump as it can go, hitting the valve cover. With it two blocked in that position it is all I can do to pry a new belt on the pulleys (or I remove both of the alternator bolts then put the belt on the pulleys and fight it into position while reinstalling the lower alternator bolt. A process that small impressionable children should not be exposed to.
![]() Then when I tighten the alternator it goes go almost to the end of the adjustment range. (Photo below) After a couple hundred miles the belt streches some and starts to squeal when the compressor starts up. So then I readjust the tension but now it is at the end of the adjustment range and a couple thousand miles later it will start to squeal. And then it is time put a new belt on and start over again. If I had another 3/4 of adjustment range I would be golden. I saw the bracket shown in the second photo on another C10 but the owner didn't know what it was off of as he didn't do the work. Every photo I have seen of a 67-72 shows a bracket similar the one I am currently using. Used to be a guy could go to a wrecking yard and hunt for brackets but now days anything more than 15 years old goes straight to the shredder.
Maybe you just need a belt that sits higher in the groove.
One that’s slightly wider. Here’s some info on belt sizing. https://www.contractingbusiness.com/...ement-fan-belt |
1971 Custom/10 - 350/3 speed, Orange/White roof Last edited by rechinca; 08-24-2019 at 08:59 PM. Reason: Typo |
Carpe manana
![]() ![]() Join Date: Dec 2010
The bracket in the first pic may be the alternator bracket for 1972 model sb motors. For pickups, I believe this bracket is a 72-only part like the doors, vent window screws, tow hooks, etc.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#10 | |
Who Changed This?
![]() Join Date: Jan 2013
To the OP- you could try a larger diameter alternator pulley.
Here's what I believe is a factory braket on my 71 gmc. No power steering.it looks the same as yours. The taller aftermarket valve covers are your issue I would say. When I got rid of the ones in the picture for stock ones I got more room for the altinater
![]() 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
![]() Join Date: Nov 2018
It appears from the photo provided that the fix is as simple as a shorter belt...but then again we aren't there.
#13 |
It looks just like the bracket on my 72 SB350
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#14 |
That bracket you are lookig for can be found at Truck Shop in Orange Ca part number 67- 13502 upper small block v8 / alt bracket / 1800 243-8947 have nothing to do with this place ,just saying where you can find that specific bracket.
#15 |
Post Whore
Thank you everyone for your help. It is now clear to me that the brackets for the alternator have been changed. I no longer have the stock 67 set up. It seems the PO used a 69-72 lower bracket and it looks as if they shortened and reshaped the stock 67 upper bracket when they installed the headers.
So my fix will be to get the proper upper bracket. Fortunately it looks like it was used on 69-72 trucks and other later model cars so it shouldn't be too tough to find one. Thanks again everyone.
#16 |
![]() Join Date: May 2010
I suggest you look only for the '72 bracket. I believe it'll give you more room.
#17 |
![]() Join Date: Apr 2016
Is there a different number of inches the bottom bracket holds the alternator away from the engine, between 72 and earlier years and aftermarket brackets? Or is buying the longer upper bracket the only thing that will allow more room? I have a 1969 truck with stock bracket and with a newer alternator it could benefit from a longer lower bracket.
#18 |
Carpe manana
To clarify, the upper bracket for 72 is a 1972 only bracket design.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 08-25-2019 at 05:31 PM. |
#19 |
This thread https://67-72chevytrucks.com/vboard/...d.php?t=581223 may offer an option. It's based on Vortec heads but the bracket should fit.
#20 |
Don’t know if it helps or muddies the waters: I have a ‘70 with the correct alt bracket setup. I had some taller MT valve covers on it and had your same problem. The stock belt length was too short to allow me to slip the belt over the alt pulley at all. The next longest belt I could find allowed me to pry it over the alt pulley but it maxed out the adjustment and the belt would squeal a lot.
Went back to factory valve covers and stock belt, all better again.
Josh '70 Custom Camper / 20 |
#21 |
Post Whore
Great! Even more information. I better score one of those 72 only brackets before they get like the extreme bend tow hooks.
