Old 12-02-2003, 02:18 PM   #1
bigblock73
yeller
bigblock73's Avatar
simple question...
Will a 81+ dash pad fit in my 73 truck and work with my 73 dash bezel, steering wheel, and lower column cover?
I know it will physically bolt in, but I am not sure of the differences between the bezels and columns throughout the years.
bigblock73 is offline   Reply With Quote
Old 12-02-2003, 03:09 PM   #2
78SilveradoSWB
78SilveradoSWB's Avatar
Jeff:
I know there is a difference in the lower steering column cover size. They go from: 73-77, 78-80, and 81-87. There were slight differences in size to accomodate the respective dash bezels. They have to match the dash bezel otherwise it won't fit.
I believe the 73-80 dash pads were shaped the same, except 79-80 had the cutout for the Vin Id. 81-87 has accomodation for the curved dash trim panel at the passenger side and I think, but not sure, but there may be a slight angle change at the dash bezel side. Definitely changes in the bezel occurred in the 84, when the wiper went to the stalk, eliminating the square cutout.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 12-02-2003, 03:12 PM   #3
bigblock73
yeller
bigblock73's Avatar
Mitch
So the 81+ dash will fit as long as i use both my 73 bezel and lower column cover?
Yes, the trim on the pass side of the pad is different...I know that, just trying to make sure a later model pad will fit (to better match my later model doors and panels)
Old 12-02-2003, 03:19 PM   #4
78SilveradoSWB
Yep, I thing it will work as long as the dash bezel and lower steering column cover match. To be sure, if you can find a 81-87 dash bezel to compare to yours to verify the angles.
Mitch
454 BB, TH400
Old 12-02-2003, 06:00 PM   #5
Jonboy
Slots go on anything!
it will work. I had an 87 pad in my 75 blazer, and used the 75 bezel and lower cover. It looks pretty good, too.
1974 Jimmy- 5.3/4L80e/NP241
Old 12-02-2003, 09:03 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
yes it willw ork as long as ya do it as described above im doin it right now!
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
