![]() Join Date: Jul 2016
Tilt column, auto column shift, converted van column, restored
Completely disassembled, bead blasted painted and set to factory specs.
Bearings and pivots were inspected cleaned and lubed. Neutral safety/back up lamp switch was moved to proper location and new truck grommets and retainer installed. The following parts are new Turn signal switch Tilt lever Turn signal lever Grommets and retainer Neutral safety/back up lamp switch Tilt pointer (to be installed) $400 shipped. Your intermediate shaft between the column and steering gear box will need to be collapsed approx 2.5” to make this a bolt in. There are many threads in the forum here about how to go about this. |
Re: Tilt column, auto column shift, converted van column, restored
Ttt
Ttt
Ttt
Column is sold to rotted71, thank you.
I have another column on the workbench, torn down ready to move the neutral safety switch and bead blast, etc. So let me know if you need a nice column, can be ready in a day or Two. I think its a motorhome column so it will be a direct bolt in. |
