Bolts!
Long story short... my engine build/swap turned into pulling my front clip and stripping down the front frame.
I am at the assembly stages and exploring options on how to deal with the hardware. Its a small thing, but not a detail I want to overlook with how much time I have into this so far. I called 3 local companies that do black oxide coating... "commercial work only". Anyone have the name of a company they have sent their hardware off to and had it cleaned/black oxide coated? How much was it? I was also looking at one of these bolt kits, any experience with them or recommendations on whos kit to go with? https://www.classicparts.com/1971-72...ctinfo/37-779/ Let me know your experiences and how the coatings are holding up. |
Re: Bolts!
AMK bolt kits (available at various restoration parts suppliers) are pretty good kits. They come prepackaged and nicely labelled. They have pretty much every kit you can think of for the 1st Gen Camaros, ...and they do have a listing for the trucks ; ) link below.
I've used them on a few Camaros and was very happy with the quality and thus far they have held up fine (noting the Camaro never sees the rain : ) https://www.amkproducts.com/ https://www.amkproducts.com/master-k...s&element=Body |
![]() Join Date: Dec 2013
Re: Bolts!
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Re: Bolts!
I work at a machine shop that makes wellhead equipment for the oilfield. We get lots of equipment coated. There are many different types of coating out there.
Nitride is a process that turns the metal black and also hardens the very outer layer of the metal. There is also phos and oil, just a surface treatment that protects items from corrosion. But I deal with these people on a daily. I have not gotten to a point of restoration with my truck YET as it really runs and drive pretty damn good - for the money I have to throw at it But here is their website. Worth a call. Might give you some ideas if nothing else. https://progressivemetalservice.com/
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
![]() Join Date: Apr 2016
Re: Bolts!
Here's an older thread with discussion about re-plating. http://67-72chevytrucks.com/vboard/s...=706453&page=2
Shady Rascal gave the name and location of a shop he uses that does low minimum charge plating. Others on the thread talk about checking feasibility of shipping to the plating shop. You may want to revive the thread to ask how it worked out for the folks who expressed interest in doing that. |
![]() Join Date: Feb 2019
Re: Bolts!
Amk
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
![]() Join Date: Feb 2009
Re: Bolts!
I had my original hardware black zinc plated. Some clear too. I may have preferred original zinc phosphate, but luck has it I'm really happy with the zinc plating. It's dark and looks great with black powder coat. I ran with zinc plating because the place is local, and I refused to send out the hardware. Too much work and impossible to replace.
Old hardware has to be spotless or the results will be poor. Any indication of rust will reveal itself after it's finished, lucky for me that was 5-6 bolts of well too many pieces ![]() IMO the black oxide on replacement hardware looks awesome, perhaps best of all. It's dark and consistent. Only a guess how durable, though with today's technology it might be very good. I've bought a kit etc., it's nice stuff. A sample of zinc plating next to replacement hardware. I imagine the appearance is the same or close for anyone using a hot bath oxide process. Course original (zinc phosphate) was lighter than all of em.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-27-2019 at 10:07 PM. |
Re: Bolts!
I ordered an underhood kit from Classic Industries and so far have been very happy with it. I'm just in the process of putting the truck back together and all the parts came listed and that has been a great help as I wasn't the one who took the poor truck apart.
My only complaints would be that it didn't come with the 2 big front fender bolts that bolt through the bottom of the inner fender (supposedly 7/16" bolts with 2 1/4" washers), nor with new clips for bolting the inner fenders in (easily available from an autobody supply store) but it does have the bolts! Otherwise a great kit. Part # SK1013 67-70 Underhood Hdwr Set |
#9 | |
Re: Bolts!
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Bolts!
Original vs AU-VE-CO bolts , AU-VE-CO makes all the nuts bolts and screws also the 72 door panel clips . you can buy a box of 50 on Amazon for $20.00 with free shipping also the fender nuts can be bought at any Lowe's home store for a few dollars.
![]() https://www.lowes.com/search?searchTerm=u+nuts https://www.amazon.com/Qty-5-16-18-S...y&sr=8-2-fkmr1
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 08-29-2019 at 02:01 PM. |
Re: Bolts!
I ended up going with the caswell plating kit. It seemed that no matter what kit I went with I would end up having to reuse some hardware and would need to plate it anyways. I will post up the results when I get started.
![]() Join Date: Nov 2010
Re: Bolts!
I've been doing some black phosphate coating at home. Basically parkerizing. I've done hardware, brackets, linkages, shift levers, etc. It's pretty easy, it's cheap and looks great. There are lots of parts that need protected but IMO don't look right painted.
