Old 08-27-2019, 05:19 PM   #1
70-Chevy
-Chris
70-Chevy's Avatar
SBC to BBC Front Suspension
I've read about 20 past posts on this subject, but get conflicting information, so I'm gonna ask again! Sorry for resurfacing this subject.
I have a 70 c-10 that had a small block in it. I put a 3/5 drop on it with new springs about 5 years ago (so the springs are relatively new). I am now going to a 496BBC and also I'm putting a Willwod disc brake kit on it with 2" drop spindles. Technically, the drop will now be a 5/5 going forward.
I want a slight rake to the truck, but not a lot.
Questions:
1) Do you think I should swap the front springs to a 2" drop BBC spring?
Or, can I leave it alone and expect a good ride with it with the SBC springs?
2) What do you think the rake will be with a 5/5 drop? Just curious how much I will need to bring the rear down.
As always with you guys, thanks in advance.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 08-27-2019, 05:25 PM   #2
70-Chevy
-Chris
70-Chevy's Avatar
Re: SBC to BBC Front Suspension
Just realized I didn't put this in the suspension forum. Sorry mods.....
Old 08-27-2019, 07:04 PM   #3
a.c.ward
I did almost the exact swap, except mines a 508 BBC from a small block 355.
i had to change the springs out, the 3" drop springs for SBC were sitting on the bump stops. I have the CPP modular spindles with 2.5" drop and CCP 12" big brake kit (at least it was the big brake kit 5 years ago when I bought it).
Could not drive with SBC springs in place, once I swapped in the 2" BBC springs, yielded almost same drop as before, but with suspension travel now and able to drive it.
post some pics and good luck
A C Ward Retired US Army
66 El Camino
67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475
a.c.ward is offline   Reply With Quote
Old 08-27-2019, 10:22 PM   #4
70-Chevy
-Chris
70-Chevy's Avatar
Thanks for the info Sir. I went ahead and ordered the 2" BB springs.
Old 08-28-2019, 11:19 AM   #5
mkmc69
mkmc69's Avatar
I'm doing the same thing with my 70, except I only have a puny 454
Where did you order your springs from?
mkmc69 is offline   Reply With Quote
Old 08-28-2019, 11:27 AM   #6
70-Chevy
-Chris
70-Chevy's Avatar
Performanceonline.com
I ordered an adjustable rear track bar from them too.
Old 08-28-2019, 01:29 PM   #7
mkmc69
mkmc69's Avatar
Ok, thanks.
Old 08-28-2019, 04:20 PM   #8
RenoKeene
Florida Edition
RenoKeene's Avatar
I'm too late for this to help but factory 1/2 ton big blocks came with stock 3/4 ton front springs. I ordered new stock 3/4's and cut one half of a coil off along with 2-1/2" drop spindles, that and 6" drop rear coils, adjustable track bar, stock shocks and SHOCK RELOCATOR KIT got me about the perfect stance on 15" wheels.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-29-2020, 11:53 PM   #9
blap
renokeene. is that gm factory 3/4 ton springs with a small block?
blap is offline   Reply With Quote
Old 01-30-2020, 12:08 PM   #10
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I'm running factory SBC coils with 1/2 a coil cut off, also 2-1/2" drop spindles, itty bitty 439 ci BBC LS killer motor...No issues, steers and rides like a Vette...
Skinny MT drag tires and wheels provide plenty of suspension clearance.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-01-2020, 11:12 PM   #11
70STOVEBOLT
70STOVEBOLT's Avatar
I went from a 250 to a 402 and did not change springs. I cannot tell the difference in ride height and it handles the same. Stock height though, not dropped.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
