Old 08-27-2019, 10:04 PM   #1
Big Blue
Big Blue's Avatar
Smile Fuel tank hoses
Please take a look at the picture, can anyone tell me where each hose goes to. I am NOT using the canister that is upfront near the Rad support.
A: GOES TO:
I BELIEVE IT IS GOING TO THE FUEL FILLER AS A BREATHER?
IF NOT USING IT CAN I PLUG IT UP?
B: GOES TO:
C: GOES TO:
I HAVE GOING TO MY ELECTRIC FUEL PUMP TO ENGINE
D: GOES TO:
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 08-27-2019, 10:42 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Fuel tank hoses
are you wanting to plug all those lines?
the 4 should be
a:fill tube vent
b:tank vent
c:suction line
d:return line
I think...
what does it go on?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-27-2019, 11:50 PM   #3
Big Blue
Big Blue's Avatar
Re: Fuel tank hoses
1979 Chevy Blazer rear tank, No, I want to know where do they go and if I am not using the canister can I plug up the return line? That would leave me with (A)
( BREATHER )This is where the thick hose that gets attached at the filler neck goes to, that is the only big hose size. Your are saying that (B) IS the tank breather? I am using (c) as my line to the electric fuel pump. Is that the suction you are talking about? AND (D) IS THE RETURN LINE that I can plug up since I am not using the CANISTER. Sorry if I made this confusing. Thanks again, John
If (B) Is the tank breather ,what do I use , would it be the breather tip that you would find on the end of the hose either on the trans or rear diff?
Big Blue ( John )
Old 08-28-2019, 01:42 AM   #4
mongocanfly
Re: Fuel tank hoses
I'm just assuming this is what you have...this is what came up when I googled your truck
#1 fill tube vent
#2 has what I think is a rollover valve in circle
#3 is your suction line
#4 should be a return...if you don't have a return style system then you can cap it off
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-28-2019, 08:09 AM   #5
Big Blue
Big Blue's Avatar
Re: Fuel tank hoses
Thanks mongocanfly,
So can I cap off off #2 and # 4. Since I am not using the canister? If I can not then, what do I put on the ends. What goes on the roll over tube?
John
Big Blue ( John )
Old 08-28-2019, 12:40 PM   #6
Dead Parrot
Re: Fuel tank hoses
The gas tank needs a vent to outside air. As gas is pulled out, air takes its place. #2 is the likely candidate. If you aren't running a canister, then use a differential vent on a short piece of hose. Of course, if Blazers use a vented gas cap, then your vent problem is solved.
If the canister and related tubing is still there, no reason not to use it. It doesn't hurt power and adds a bit of economy as it saves the fuel vapor that would otherwise be lost to the air. Plus those differential vents cause gas smell. My 75 has two of them and on a hot day, you can really smell the gas evaporating off.
Dead Parrot is offline   Reply With Quote
Old 08-28-2019, 01:33 PM   #7
mongocanfly
Re: Fuel tank hoses
^^^ what he said ^^^
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-28-2019, 06:25 PM   #8
hatzie
Moderator
hatzie's Avatar
Re: Fuel tank hoses
A - Fill pipe vent line. Use it. It'll want to kick off the automagic gas pump handles if you don't connect the fill pipe vent line.
B - Tank vent. Use a differential vent cap on a hose terminated so the cap is above the level of the fill pipe... or route it to the VENT connection a 1970's 3 hose charcoal can.
C - Suction line to the fuel pump.
D - Return line from a three hose fuel pump. If you don't want vapor lock issues you need to plumb this up.
You don't have to use the overcomplicated BS job GM came up with with forty lines attached to it. The 3 hose 1972 Corvette evap can is easy to plumb and it keeps the fuel vapor sequestered til you're driving so your garage doesn't smell like you have a gasoline leak. The purge valve vacuum actuator is connected to ported vacuum. The big fat vapor purge line is teed into the PCV hose with J30R7 fuel vapor line. It costs you nothing in performance to use one and it keeps SWMBO happy.
There are other GM rigs that use this can but that's the one I know has one.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
