08-28-2019, 05:55 AM | #1 |
71 brakes
Hey fellas does anyone have pics of where the return spring goes on the foot brake pedal?
I dont think mines on it, when I push it down it stays on but when I release it I have to lift it back up manually 71 c10 |
08-28-2019, 06:41 AM | #2 |
Re: 71 brakes
This is on my 70 k5. Not sure if they differ
Justin 1970 Blazer in progress |
08-28-2019, 08:08 AM | #3 |
Re: 71 brakes
08-29-2019, 12:24 AM | #4 |
Re: 71 brakes
08-29-2019, 09:56 AM | #5 |
Old member
Re: 71 brakes
Here is a link on when mine broke. I bought another used one and installed it. The spring is part of the assembly.
http://67-72chevytrucks.com/vboard/s....php?p=7608320
08-29-2019, 03:35 PM | #6 |
Re: 71 brakes
There is also a spring on the end of the park brake cable inside the drum brake assembly left and right on the rear axle. So a total of three return springs for the system. It is very common for the park brake cables at the rear axle to be full of crud after 50 years of service and not returning properly. A good idea to remove completely from the truck for a full inspection and cleaning.
Steve weim55 Colorado |
09-04-2019, 07:25 PM | #7 | |
Re: 71 brakes
09-18-2019, 02:16 AM | #8 |
Re: 71 brakes
Not telling?
09-18-2019, 05:02 AM | #9 |
Re: 71 brakes
That is the spring that makes the release handle go back in when you let off of it. It has nothing to do with the pedal coming up when the release is pulled.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
