08-28-2019, 08:30 AM | #1 |
thoughts and opinions
I am chomping at the bit to hit the order button on a Dakota Digital Gage board. I am down to either the HDX or the RTX series.
RTX looks a little more original to me. what are your thought and any experience or concerns with DD. and yes I know there are the Purist OEM guys that will say "NO WAY" out there and your info is welcome too.
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
08-28-2019, 10:31 AM | #2 |
Re: thoughts and opinions
I definitely prefer the RTX. Not to muddy your waters but have you looked at new vintage USA? They have some good looking ones. Especially retro ones.
http://newvintageusallc.mybigcommerc...ew-category-3/ |
08-28-2019, 06:04 PM | #3 |
My choice would be Classic Instruments. Check them out if you haven't already.
https://shop.classicinstruments.com/...-truck-package
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
08-28-2019, 08:08 PM | #4 | |
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla” 1967 Camaro 327 ‘glide cruiser “Bailey” |
08-28-2019, 08:56 PM | #5 |
Holy Schneikes those gauge packages are expensive!!!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
10-13-2019, 07:18 PM | #6 |
Well I pulled the plug in the RTX series with a couple of add ons trans temp and outside temp and compass sensors. Waiting for them to arrive
10-13-2019, 09:12 PM | #7 |
Looking forward to hearing a review from you on these. I have decided on the RTX gauges as my next purchase. I like the look coupled with the more modern features.
11-02-2019, 05:26 PM | #8 |
As far as a review. It will be a long while before I get them Installed and running
But at least they are in the garage now on the shelf
11-02-2019, 09:20 PM | #9 |
Old member
I like my 'Speed Hut gauges' GPS speedometer and no calibrating it just drive it. Life time warranty also.
Yes all the new gauges are expensive.
