08-28-2019, 10:39 AM | #1 |
Anyone know what to use for this?
The stock oil pressure sensor in my truck is made for a 6 cylinder. As you can see, it is too small for the regular sbc/350 port, the whole thing can fit inside the port.
What would you use to adapt this? How do I measure the threads on the end of the nipple since it's so short?
1968 GMC 3/4 Ton 4x4 K20 / 2500 1971 Chevrolet Chevelle Malibu |
08-28-2019, 10:42 AM | #2 |
Re: Anyone know what to use for this?
You're missing a brass fitting which should even have been on the 6cyl
08-28-2019, 10:46 AM | #3 |
The fitting pictured is a compression fitting, you need the female brass transition fitting to reg pipe thread into the block....it's about 1 1/4" long.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
08-28-2019, 10:54 AM | #4 |
The 6 cylinder is long gone. Where can I get that fitting?
08-28-2019, 01:21 PM | #5 |
Post Whore
Napa will have it. See link. I recommend taking the old one with you to make sure you get the correct size for the tubing and be sure to check the thread size (NPT) of the block.
You will have to remove the old fitting from the tubing, as the old compression ferrule won't seal with the new fitting. There are literally a dozen of size combinations. To do this it is important not to distort the tubing. Use a tubing cutter to achieve this. You may have to remove a burr from the inside of the tubing after you cut it. Use an Exacto knife or a deburring tool if you have one. There are videos on how to install the fitting. The important part is to only snug the nut that tightens the ferrule. Then check it for leaks if it leaks then tighten it up a 1/4 turn more and check it. Too tight and you will block the tube or split it and then its start over with a replacement ferrule. Good luck. https://www.napaonline.com/en/p/BKNEDE76560
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-28-2019, 01:44 PM | #6 | |
That was a very professional and thorough answer. Thank you. I will do as you recommend.
08-28-2019, 04:15 PM | #7 |
Post Whore
You are welcome!
08-28-2019, 06:46 PM | #8 |
If you can't find what you need PM me I have a drawer full of these fittings.
08-28-2019, 11:14 PM | #9 |
08-28-2019, 11:46 PM | #10 |
It's available still. NAPA stocks the weatherhead #'s This sight shows the explanation for it. http://rmcavoy.freeshell.org/Oil_pressure_gauge.html
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
08-28-2019, 11:49 PM | #11 |
It eliminates the need for a loose 3 pc compression union.
08-30-2019, 03:17 PM | #12 |
Here's a thread with new kits: http://67-72chevytrucks.com/vboard/s...d.php?t=648080
72 C10 lwb fleetside -stock 350/350 combo |
08-30-2019, 07:18 PM | #13 | |
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-31-2019, 10:00 PM | #14 |
Love you all with your indefinite wisdom
09-01-2019, 05:47 PM | #15 |
Moderator
"Indefinite" ???
Perhaps you meant "infinite"... Some say "Tomato" some say "Tomatoe"... Lots of experienced and skilled folk on this forum....most with a serious sense of humor....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
09-01-2019, 06:07 PM | #16 |
or a whole lotta
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
09-01-2019, 06:22 PM | #17 |
Old member
Any good hardware store will have the fittings. A nipple with a union on one end screw the nipple into the block then you screw the tube fitting you have into the union.
09-01-2019, 07:18 PM | #18 | |
