Old 12-02-2003, 05:22 PM   #1
Devil'S Ride
NP 203-205 T-Case Adapter....
Ok, so I have heard that you can stick the NP 203 planetaries toa NP205 then bolt all that to yer tranny, and have yerself a dual T-Case 4-by.... in the end it leaves you with a fairly bulletproof 6:1 crawl ratio....if this is the case, does anyone know where I can pick up an adapter, an for how much? and also, how much work is it to do suck a conversion?? I am building a new TH400 for my rig and I was gonna go with the NP205 cause Im tired of the 203 chain driven crap...and when I heard of the dual setup, I got excited, so any info would be much appreciated!!
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 12-02-2003, 05:41 PM   #2
Devil'S Ride
Sorry guys, meant for this to go into the 4x4 page...but any help is appreciated...I may copy it and post it over there too tho......
thanks again..
The Devil
Old 12-02-2003, 05:44 PM   #3
chevychic
chevychic's Avatar
I was going to suggest this be on the 4X4 board. Lot's of great knowledge over there.
Btw, welcome to the board from your neighbor in Medford Oregon
ChevyChic
86 Chevy K-10
If I can't be a good example, then I'll just have to be a horrible warning.
"You're braver than you believe, and stronger than you seem, and smarter than you think"
- Christopher Robin
chevychic is offline   Reply With Quote
Old 12-02-2003, 06:22 PM   #4
Scrubby
Check out GMTrucks.org
http://www.offroaddesign.com/catalog/doubler.htm
Scrubby is offline   Reply With Quote
Old 12-03-2003, 02:20 PM   #5
alf4444
alf4444's Avatar
off road design does sell this kit you basically use the range box out of the 203 mated to a 205 for ultra low crawling. I recently picked up a twin stick 205 that i'm swapping in to replace my 203 and thought about doing a doubler but think i 'll try it out with just the 205 in moab first then decide. try coloradok5.com for more info alot of guys on there have done the swap
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
