08-28-2019, 08:25 PM | #1 |
Old member
Ramp truck LED
I bought this LED bar to go on my 71 but ended up buying new tail lights and cargo 3rd brake light in stead.
So I decided I would use it on the ramp truck. I had the flat 4 pin connector so why not. Man that was a job. The truck wiring was a mess under the truck. PO had cut and taped up all kinds of splices with no connectors just tape. I cut 8' of wire out of the harness and redid it all. The lights work well now. I even went and bought new flasher and LED tail lights to go in it also. Made a world of difference.
08-28-2019, 09:31 PM | #2 |
Re: Ramp truck LED
Are those the ones that push into the rubber ring?
If so,that's what I have on my 82 hauler.I have the rectangular ones up on the rack too. Also,led side markers. Sure is bright at night! Look good too! Mike. |
08-28-2019, 10:10 PM | #3 | |
Old member
Re: Ramp truck LED
I have LED driving lights up front. Here is the front.
08-28-2019, 10:12 PM | #4 |
Re: Ramp truck LED
Looks good. I can see you! I have four of those round tail lights laying around, and crossover harness from the '95 I totalled that had a utility bed. I just need a truck for them
08-28-2019, 10:29 PM | #5 | |
Old member
Re: Ramp truck LED
It's all better now though. I may start adding the LED side marker's soon. I added the relays up front for the head lights and I may get a set of new head lights for it.
