Old 12-02-2003, 05:43 PM   #1
Devil'S Ride
T-Case question....
Yeah, Im a bonehead, I put this in the 73-87 message board, but meant it for here, so I brought it over here, mebbe you guys can help me out...thanks!!
Ok, so I have heard that you can stick the NP 203 planetaries toa NP205 then bolt all that to yer tranny, and have yerself a dual T-Case 4-by.... in the end it leaves you with a fairly bulletproof 6:1 crawl ratio....if this is the case, does anyone know where I can pick up an adapter, an for how much? and also, how much work is it to do suck a conversion?? I am building a new TH400 for my rig and I was gonna go with the NP205 cause Im tired of the 203 chain driven crap...and when I heard of the dual setup, I got excited, so any info would be much appreciated!!
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 12-02-2003, 06:25 PM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
Well, not a 6:1 ratio since the gear reduction of the np203 is 2.01:1 and the gear reduction of the 205 is 1.96:1, so you get a combined gear reduction of 3.94.
Click here for lots more information.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 12-02-2003, 09:54 PM   #3
Milenko72276
here ya go
http://www.offroaddesign.com/catalog/doubler.htm
72' Camper Special,454,th350,np205,4.56 locker,dana44 with spool,13" of lift and 44" boggers.soon to be 23" with rear disc brakes
Milenko72276 is offline   Reply With Quote
Old 12-02-2003, 10:11 PM   #4
Devil'S Ride
Cool, thanks guys, 'preciate the input...now I just gotta go rob a bank.....
The Devil
Old 12-03-2003, 01:08 AM   #5
Pont
I need another Barley Pop
Pont's Avatar
Devil's Ride, sorry I can't answer your question about the 203 setup but I just wanted to welcome you to the board. Seeings how your so close and all, were practically neighbors!
Good luck on the t-case combo, keep us posted on your progress.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 12-03-2003, 01:15 AM   #6
Devil'S Ride
Hey man, yeah I was just thinkin we were kinda near each other, an I find myself in grants pass at least once a month, so we'll have to catch up sometime.....
as for the T-Case thing, Im gonna have to pass for a while...my "poor college kid" income only allows for so much....:P
But I am gettin my TH400 an NP 205, so I'll just stick this TH350 an NP203 in a corner an keep it handy fer a while.....but yeah....too many ideas, never enough money....wish school wasnt so damned expensive!!!
The Devil
Old 12-03-2003, 04:17 AM   #7
Scrub
Collector of rusty Items
Scrub's Avatar
Welcome to the board from another Oregonian.
Make sure you get the t400 specific 205. There are different inputshafts for a 4speed, 350 and 400. And I think at least 2 different t400 inputs.
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 12-05-2003, 12:55 AM   #8
1FaastC10
1FaastC10's Avatar
dont mean to hijack the thread, but does a double t-case fit under a stock floorboard in say, a Blazer? what type of offroading is this setup best suited for? mud and trail use, or crawling? how is the linkage setup for both cases?
1FaastC10 is offline   Reply With Quote
Old 12-05-2003, 06:43 AM   #9
Devil'S Ride
Should fit in most Chev/GMC applications, least from what Ive heard, have a friend that has one on a heep too,but I dunno how it is fitted under there.... It ends up giving you a 4:1 crawl, which is pretty low for a street driven play truck, IMO, but would be good for some *mild* rock crawlin, good for mud an trail use as well. From what I have heard its good all around. I also believe that it uses a twin stick. IE you shift your t case to 4 lo, then if you need a lower ratio, pull the other tcase into lo, an yer set.....
The Devil
