4l60 trans fluid type
Hey,
Guys just picked up a 97 1500 with a 4L6O trans with just under 20000 miles on it wanting to do a filter change on it what type of trans fluid is recommend for this trans with this mileage Thanks for any info |
![]() ![]() Join Date: Jul 2002
Re: 4l60 trans fluid type
Dexron 3 was recommended, but no longer made. You'll probably need to run Dexron 6 (VI). If the tranny is not goofing up and you don't know the history, changing the fluid on one with that many miles may have it start to act up. I have been numerous times told not to change unless it fails as it may cause more issues. I am no expert for sure, but have followed that rule myself.
#3 | |
Tranny fluid is a super cleaner. The new fluid will clean up things which may be all that is holding things together. Least that was the simple explanation.
Only Amsoil
After I did my first oil and filter change (bought new) I used Amsoil ATF. I've never done anything to the tranny in 270K miles other than filter and oil. I have even towed way more than I should have. I'm still on the original tranny.
I am a strong believer in amsoil and will never use anything else. I won't kid you it's expensive at around $14 to 15 a bottle but if you save yourself some headache, it's worth it to me. Also I don't buy into not changing it if there is no problem way of thinking. At some point it will overwhelm the filter and potentially other problems. My feeling is, if changing fluid creates problems, the problem was there already and you only caused it to show up. Lack of maintenance is never a good idea. Fluid also gives higher temp protection that breaks down over time and needs to be renewed so the temp range stays high enough. Last edited by speedygonzales; 08-29-2019 at 12:33 PM. |
#6 | |
driving is in my blood
Changing the fluid is not the issue. Power flushing the system is the issue. Change the fluid as much as you want. Just don't use a machine to do it. Although at 20k I wouldn't worry about a machine either. Its not enough mileage to get dirty inside unless it was seriously abused.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
#7 | |
lol so he read your misprint correctly thats awesome!
At 200k, do not flush the trans.
The only thing you can do is drain the fluid into a clean pan. Strain it through paint filters. Change the filters, and gasket on the transmission. Use the old fluid again, and top off as needed. Use a cheap atf so it has less cleaners in it. As high quality stuff may start attacking the clutch packs.
That.is why you never change the fluid if it has a burnt smell. Also transmission fluid like oil does not have a definitive life span. If you beat on your engine like it owes you money the 5000 mile oil change may only be 3000. My work van needs the tranny fluid done every 20000 max. It starts showing age at 10-15 usually. You have to gauge oil life span by visuals, and texture. If it looks bad it likely is, and change it. |
It's your peace of mind and no amount of talking is going to change it
You are on the right path. Oil and filter change. Extra deep cooling pan and added capacity.
The BS about tranny fluid doesn't experience break down like oil is just that, BS. I can show you source after source that explains that. It breaks down like any other lubricant with additives. I thought it was important to put in the added (first hand experience) of fluid that has a much higher break down temp than most from the day our vehicles were introduced. Last on the subject of new fluid attacking some (unknown) something or other. That's definitely BS. What would it clean away? Sludge? Holding a seal in place? Attack a sludge clogged clutch pack? Make it slip? Really? Who wants to rely on a clutch pack that works because it's pack full of sludge when you're on a long trip with the family? I don't know where the BS thinking of changing fluid if it isn't burnt is bad started but it's pure unadulterated Bu-- Shi+ |
| Bookmarks |
