Old 08-30-2019, 01:02 PM   #1
Daaaanz67
Auto six speed differences.
I recently was given a 2016 6l80E with 56 thousand miles. It came out of a van so it has the slip yoke. The motor that it was attached to was a LQ9. My question is what is the difference in this trans and the six speeds that come in the Camaro size ect. I know the Camaro has that funky fixed yoke. Also what the difference between this trans and the 6L90. Trans GURU’S please help.
Daaaanz67 is offline   Reply With Quote
Old 09-01-2019, 01:10 PM   #2
Daaaanz67
Re: Auto six speed differences.
Bump to the top. Anyone?
Old 09-01-2019, 08:34 PM   #3
AMERICAN PICK-UP
they did not make a LQ9 engine that year.. the last year for the lq9 was 2006... can you get a vin number?...and if it came out of a 2016 van it would be the L90E not the 6L80E.... and the engine would be the L96 6.0 engine...
AMERICAN PICK-UP is offline   Reply With Quote
Old 09-02-2019, 03:02 AM   #4
Daaaanz67
Ok I’ll ask my friend. Think he has the vin. I know the engine is a 6.0 cast block with aluminum heads.
Old 09-04-2019, 09:05 AM   #5
YoungPup1977
Ask your friend what the RPO code is for the trans, it will tell you if its a 80 or 90. Ask your friend for the driveshaft for you to use the front yoke off of it. Its free. one less thing for you to buy when you build your driveshaft to fit the vehicle.
YoungPup1977 is offline   Reply With Quote
Old 09-04-2019, 12:23 PM   #6
Daaaanz67
Ok here is what I got from him, 1GB6GUBG3H1106962. Yep got the yoke. Where is the RPO code somewhere on the trans.
Old 09-04-2019, 01:36 PM   #7
YoungPup1977
The RPO codes are normally found in the glove box or inside the drivers door ID sticker.
It will be a 3 letter RPO code.
The 6l80 will be MYC
The 6l90 will be MYD I believe.
Old 09-04-2019, 08:32 PM   #8
Wildkarde
vin decodes to 2017 express 3500 with l96 (6.0 with rectamgle heads and flex fuel) and a 6l90
Wildkarde is offline   Reply With Quote
Old 09-13-2019, 11:21 AM   #9
Daaaanz67
Sorry for the late response. Thanks for the info guys. I would get the info off the van but it’s already been burned up for the local fire department training. So then what is the difference in this six speed and the ones that come in Camaro.
Old 09-19-2019, 01:33 PM   #10
Daaaanz67
Anyone?
Old 09-24-2019, 05:48 PM   #11
AMERICAN PICK-UP
The camaro uses a 6L80E..... alot smaller transmission than the truck and van 6L90E..... the camaro uses a fixed yoke... the truck and van uses a slip yoke.... but both do have a internal TCM.(transmission control module)... be carefull if you try to use this trans... it does require that the tcm to be flashed... and it wont work with all engine computers......
Anyone?
