08-31-2019, 09:36 AM | #1 |
1966 gmc
I am new to this forum. I seem to be registered to the 67-72 site but would rather be on the 60-66 site I dont know how to fix that. Anyway my question is about swapping engines and trannys, I am looking at a 66 gmc i really like because it is a long wide box with a big back window. The body is in pretty good condition. Unfortunately for me it is a powerglide with a mid 70s small block chevy in it. I cannot live with an automatic and dont care much for the V8 either. I have a 292 and sm420 but with the offset motor mounts on the 292 would a 250 or even a 230 be an easier swap? My main concern is motor mounts, crossmembers and getting everything located properly. Perhaps I should keep looking but the BBW is very attractive. Any thoughts on this?
08-31-2019, 07:08 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: 1966 gmc
292 did take a different passenger side mount, 230/250/v8 are the same
Btw, the 67-72chevytrucks.com forum page is what you signed up for, there are tons of other GM trucks represented here with their own page. Welcome to the forum!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-31-2019, 09:02 PM | #3 |
Re: 1966 gmc
I think the tower for the motor mount just gets moved on the crossmember. So the 292 will bolt in.
However if the crossmember for the bellhousing has been removed to fit the powerglide in then your trans won’t bolt back in. The bellhousing mounts on the crossmember and the trans hangs off the bellhousing. Also the sm420 needs a high hump floorboard for clearance. |
08-31-2019, 09:42 PM | #4 | |
Re: 1966 gmc
08-31-2019, 10:21 PM | #5 |
Re: 1966 gmc
Shouldn’t be too hard to swap then.
Give you something to do over the winter. |
08-31-2019, 11:56 PM | #6 |
60-66 Nut
Re: 1966 gmc
The 292 engine mounts from the 1 ton will bolt right into the 1/2 ton frame.
10-09-2019, 08:06 PM | #7 |
Re: 1966 gmc
On followup, I did buy the 1/2 ton it did turn out to be a 65 registered wrong minor detail. And now I have both trucks side by each so hope to be starting this new project soon.
10-10-2019, 05:38 PM | #8 |
Re: 1966 gmc
Hello from a fellow Brandonite! I sent you a pm.
10-10-2019, 07:04 PM | #9 |
Re: 1966 gmc
It's funny how people's tastes are different.
I just took out my 250 and can't wait to get rid of that loud 4 sp. to put in the auto, but that'll be a spring or summer project. The 250 ran good if you want it and I do have the seal kit for it, but it could use a cam shaft . A 292 would be a better choice if you can find one because IMO the 250 just doesn't have enough oomph. The 68 short box I used to have seemed to do a little better with it. |
10-10-2019, 08:36 PM | #10 | |
Re: 1966 gmc
