![]() Join Date: Jun 2014
LS Power steering pump, Hydroboost vs non-hydroboost
Does anyone know if the power steering pumps with Hydro boost have higher pressure then the non-hydro boost pumps? The only difference I can find so far is they have an extra re-turn line.
I am working on power steering lines this weekend on the 67. Thanks |
Post Whore
![]() ![]() Join Date: May 2015
Re: LS Power steering pump, Hydroboost vs non-hydroboost
I read all I could find on the 2 pumps and never got a clear answer....so I added a extra return fitting to my stock non-hydroboost pump....I also have a hydroboost pump on my C30 and see no difference between the 2 other than the extra hose barb
![]() Join Date: Aug 2004
I’ve heard if the donor vehicle had a steering box you are ok, and if it had a rack and pinion you will have low pressure. I don’t know if this is legit or here-say.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I hadn't thought about it but that makes sense since a R&P operates at a lower pressure than a steering box.
Waiting for some good numbers, on either one!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
Pressure you can adjust with a spring on the discharge port of the pump. Flow is a function of displacement of the pump. A hydroboost and a rack will take more flow than just the rack.
I'd run the type 2 Saginaw pump that came on your LS motor first to see how it works. Is there any LS motor that came in a truck or car that didn't have a rack and pinion? Off road cars running the LS Saginaw pump often use a ram steering setup and there's higher flow Saginaw pumps to meet the higher demand of the ram steering. If you need more flow, you can buy a bigger pump from Howe Steering and several others. LS trucks have a different steering pump shaft size than cars do, so be careful. They also sell different pullies for the Saginaw TC pump that will change the flow rate. |
Chiming in here to learn as my swap 5.3 has 3 fittings and I was trying to determine if I could just cap one off and use it or needed to get a 2 port pump. I’m assuming my donor had hydroboost.
Post Whore
yes. you can just cap off one of the return line ports on the tank..no problem..
#10 | |
