08-31-2019, 01:49 PM | #1 |
18 in Steel Wheels?
I am curious if there is a cheap(er) option for 18in steel wheels that will fit the 6lug trucks. I am planning to do a brake conversion, but am not ready to spend coin on expensive wheels. Would prefer to just get some cheapo steel wheels for now. Any suggestions on what fits?
08-31-2019, 02:03 PM | #2 |
Re: 18 in Steel Wheels?
Not sure exactly what your looking for but you can check mobsteel and wheelvintiques. They both have 6 lug options and typically in the 18” sizes. Cheap(er) is a relative term, good luck in your search.
Mobsteel Wheelvintiques
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green Last edited by KMC3420; 08-31-2019 at 02:14 PM. |
08-31-2019, 04:38 PM | #3 |
Old member
Are you going with a bigger front brake kit? If your just going to a normal disc kit you can run the rally wheels in 15". They look good and you can find them cheap on craigslist in most area's.
08-31-2019, 06:55 PM | #4 |
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust) |
09-01-2019, 09:54 AM | #5 |
I was hoping for maybe some factory takeoffs off any other vehicles that may work temporarily. The truck won't be driving much for awhile, and I won't be ready to measure and choose a style of wheels for some time.
