Old 09-01-2019, 01:40 PM   #1
truckdude239
truckdude239's Avatar
neutral saftey switch
so i am using a van tilt column in my 71 c-10 and had to remove the neutral saftey switch fromt he column as the brake rod hits it and broke it soo. i got to thinking why cant i use the stitch on the side of the 4l60e as my neutral switch and back up light switch? so amone have a pin out for that switch on a 2004 silverado 4.8 4l60e?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-01-2019, 03:23 PM   #2
YoungPup1977
Re: neutral saftey switch
Not sure of your exact connector on the side of your 4L60E, but in 2004 GM used this connector.
YoungPup1977 is offline   Reply With Quote
Old 09-01-2019, 03:30 PM   #3
truckdude239
I will try to crawl under and snap a picture of the switch that is there so i can find the right plug for it and know which i need
David fuller
2012 Subura outback
1999 honda accord
Old 09-01-2019, 09:42 PM   #4
ls1nova71
ls1nova71's Avatar
I've posted the diagram on how to wire it up several times in the last couple of months.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-01-2019, 09:59 PM   #5
truckdude239
Thanks man ill find it
David fuller
2012 Subura outback
1999 honda accord
Old 09-08-2019, 08:55 AM   #6
YoungPup1977
Can you post the thread that has your info in it, so this thread is not a dead end for others to find in their search thanks.
Old 09-08-2019, 04:57 PM   #7
Pontitruck
Pontitruck's Avatar
http://67-72chevytrucks.com/vboard/s...=783024&page=2
Pontitruck is offline   Reply With Quote
Old 02-17-2020, 10:23 PM   #8
truckdude239
Picture of pinot
David fuller
2012 Subura outback
1999 honda accord
Old 02-17-2020, 10:27 PM   #9
truckdude239
Let me see if I have this right I can bring my backup lights
hot to pin c and out on pin f
Can I bring starter signal in on e and out on g?
Will switch on trans stand anought current for starter signal or am I going to need to wire a relay in? And use the relay to carry the current for starter signal?
David fuller
2012 Subura outback
1999 honda accord
Old 02-17-2020, 11:07 PM   #10
FAKKY
More than a couple.
I reached out to admins about getting it stickied ..... and never heard back.
Be good for others to try and get it done as well.
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 02-17-2020, 11:09 PM   #11
ls1nova71
ls1nova71's Avatar
You are correct on the pins for the back up lights and the starter, but you will definitely need a relay for the starter. You will likely smoke the NSS on the first start going straight through it without the starter relay.
Old 02-18-2020, 02:32 AM   #12
truckdude239
Thanks!!
David fuller
2012 Subura outback
1999 honda accord
Old 05-27-2020, 01:49 PM   #13
truckdude239
Thanks guys got it all wired up with relay now have a nss safety switch and backup lights again!
David fuller
2012 Subura outback
1999 honda accord
