Old 09-01-2019, 05:42 PM   #1
63frankintruck
Powersteering box rag joint issues
Hey guys, I have a 63 c10 that I’ve converted to power steering and the power steering gearbox is stamped 7802644L. I ordered a rag joint for what I thought would be a 72 Monte Carlo thinking these are all the same gearboxes but the rag joint that came in doesn’t fit the splines on the gearbox. Can anyone tell me what type rag joint or what number rag joint I need? Thanks for your help in advance!
63frankintruck is offline   Reply With Quote
Old 09-02-2019, 11:19 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Powersteering box rag joint issues
You will have to count the splines on the shaft of the gear box.
Old 09-03-2019, 06:33 PM   #3
63frankintruck
it looks like mine is .720 diameter and 30 spline? (I had a hard time counting the spines but I think it's 30)
If this is correct, what rag joint should I order?
Old 09-03-2019, 06:55 PM   #4
The Rocknrod
Moderator
Slow down - Now what is the size of the steering rod that the rag joint attaches to?
Old 09-03-2019, 08:03 PM   #5
63frankintruck
the rod that comes from the column?
I used a 72 monte carlo steering column (the shaft on that is about 3/4
Old 09-03-2019, 08:58 PM   #6
The Rocknrod
Moderator
Is it a Double D shaft? Splined?
Where I'm going with this is once you "know" what each side is you can look here and buy what you need - https://www.ebay.com/sch/i.html?_fro...joint&_sacat=0
Old 09-03-2019, 09:02 PM   #7
63frankintruck
double d
small part that bolts to the rag joint is 3/4 and that telescopes into the outer sleeve of double d that leads to the firewall (that part is 1.0)
Old 09-03-2019, 09:04 PM   #8
The Rocknrod
Moderator
Originally Posted by 63frankintruck View Post
double d
small part that telescopes into the part that bolts to the rag joint is 3/4 and the outer sleeve of double d is 1.0
3/4" 30 spline X 3/4" DD Rag Joint:
https://www.ebay.com/itm/4NEW-3-4-DD...wAAOSwAF5UZQoW
Old 09-04-2019, 05:59 AM   #9
63frankintruck
Thanks! I have other issues that cause the rag joint to tear. Not sure what I’d going on. I installed a disk front end conversion kit from POW That uses original drag link. The tie rods in passenger side seem to be too long( wheel is turned somewhat while drivers side is straight and passenger side tie rods are adjusted to shortest length)
Anyway what started this whole thing was I was moving my truck without any engine or transmission in stalled and when I turn the wheel a couple times the rag joint just failed. It was a rebuilt rag joint. I’m not exactly sure what’s going on
Old 09-04-2019, 12:49 PM   #10
SCOTI
SCOTI's Avatar
Is it possible the reinforcement clip for the rag-joint disc/material was not installed correctly or if the disc/material was soaked w/power steering fluid? Both can have a negative impact.
I had a rag-joint (HELP/Dorman part) that failed in a similar fashion (turning wheel while vehicle was not running). It had less than 7k miles on it.
I swapped to a Jeep Cherokee XJ shaft to eliminate a future failure: http://67-72chevytrucks.com/vboard/s...d.php?t=505196
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-04-2019, 07:56 PM   #11
63frankintruck
yes, I did not have a reinforcement clip on the original rag joint ( I thought that was just to make ground contact with the horn)
Still curious as to the POL steering linkage. It seems that the tie rod ends were too long for the passenger side.
Old 09-04-2019, 09:15 PM   #12
SCOTI
SCOTI's Avatar
Tie rods should both be the same length; just a L & R.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-05-2019, 08:22 PM   #13
63frankintruck
Thanks guys for the help. I have a new set of tie rod ends coming for the passenger side and new rag joint, so we will see what happpens
