Old 09-03-2019, 09:55 AM   #1
coacharmstrong1990
New Wiring Harness-No shift
I just installed a new BP-Automotive Wiring Harness and the quality and ease of installation is great. My engine was running like crap with the homemade harness but is running great with he new harness. However my transmission has stopped shifting. With my janky homemade harness it would shift but now it will not. could this be TCC lock up issue? maybe i have the pole switched in the brake switch? IIRC the purple wire is going to the 3rd post from the top and the 12v constant to the bottom post?
maybe a fluid level issue?
thoughts, ideas?
coacharmstrong1990 is offline   Reply With Quote
Old 09-03-2019, 11:32 AM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: New Wiring Harness-No shift
Tcc would not cause that. Checkyour basics first. Fluid and fuse.
Top post and bottom post? No idea what your talking about. When talking about wires and connector. e specific what connector and what pin number
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 09-03-2019, 12:25 PM   #3
BigBird05
You didn't give any details about what type of truck you are working on. You need to tell us everything about the truck if you what us to try and help.
BigBird05 is offline   Reply With Quote
Old 09-04-2019, 10:57 AM   #4
coacharmstrong1990
1968 C10- Gen III 5.3 cammed and 4L80e
got it fixed the main plug was plugged in upside down
Old 09-04-2019, 08:34 PM   #5
Wildkarde
i didnt think that was possible, at least you got it fixed.
Wildkarde is offline   Reply With Quote
Old 09-04-2019, 10:21 PM   #6
YoungPup1977
Can you explain what the main plug is, just wanting to know if I ever have this issue I will know what to do. Can you take a pic of this as well. Thanks
YoungPup1977 is offline   Reply With Quote
Old 09-04-2019, 10:29 PM   #7
ls1nova71
ls1nova71's Avatar
Most likely he's talking about the big round plug that plugs into the transmission itself. It has small detents to keep it from being plugged in backwards, but they are small enough that you can do it. Seen it done a couple of times.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-04-2019, 10:55 PM   #8
YoungPup1977
What year of 4L80E is it ? early years ?
Hey LS1 can you answer this too ?
