Just bought a 57
So I just got a 57 small window. Rust free body from Calif. All original suspension, has a 350/350and that's it. I'm liking it just the way it is and I don't want to do the 2 year replace everything routine. It drives very well, stock straight axle, drum brakes etc. I was surprised that it turns nicely and stops straight with original stuff. The only thing I would kind of like to do is maybe lower the front a couple inches. I saw some 2.5" lowering leaf springs on Brothers website. So my question is, do those lowering leaf springs work well, any better pricing then Brothers?
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
![]() ![]() Join Date: Nov 2008
Re: Just bought a 57
If you do it, buy Posie’s Super Sliders. They have two leafs and a pocket pressed into them for a Teflon disc to eliminate friction. BUT, they may not lower the truck X number of inches because your springs have likely already sagged quite a bit from stock 60 years ago.
Nice looking truck. Congrats!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Congrats! Clean truck! A guy down my street has a 56 in the same color.
I'm with Dan...Posies Super Sliders. You'll love em. If you'd like I can dig up a side view photo of my truck with Posies springs before I had my stock axle dropped. It can give you an idea of the stance you'd get.
My 57 truck project |
Post Whore
![]() ![]() Join Date: May 2015
Sweet truck..!!
Thanks for the tip on the Posies. Looks like it might be exactly what I'm looking for. Price is reasonable too. Just have to check that my tires won't rub with a 3" drop
If you have a local spring shop they can re-arch your current springs or reverse the eyes for a lower stance. I'm not familiar with TF leafs but on most vehicles a simple eye reversal is good for a 2-1/2" drop.
Nice truck.
1951 Chevy Panel Truck |
Will lowering the front 2-3" with springs cause any issues with the steering arms/linkage etc? Any other changes necessary due to lower springs?
I just purchased a 57 Chevy 3100 also, and I'm interested in the same information! Thanks for starting this thread!
Incapable of not thinking about my truck at least every other minute ![]() |
#9 | |
Hope this helps...
#10 | |
You have Posies front and rear. Shackles, did you have to replace shackles also? These weren't lowering shackles in addition to the springs?
#11 | |
http://www.posiesrodsandcustoms.com/...truck-springs/
Looks good. Looks like same size tires all around, what size?
#13 | |
Coker Classic L78-15 all around.
#14 |
Any chance you have the posies for sale?
#15 |
No they're still on my truck...
#16 |
You have it lowered 6" now then.
#17 | |
Who's/what's Sid?
#18 |
https://droppedaxles.com/
Check out his site...Sid drops stock axle's the old way. 3 or 4 inches. And he'll re-do your kingpins and make any necessary mods to your steering arms so it all goes back in smooth. Here's my truck with the Posies springs after the axle was dropped 3".
#19 |
Your drop axle must be narrowed to get those wheels/tires inside the fenders with that drop
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED Last edited by mgchevyparts; 09-04-2019 at 09:24 PM. |
#20 | |
I used to get an occasional tire rub on my left fender when I'd turn the wheel hard on U-turns. Ever since I put a front sway bar in last week it hasn't rubbed and eliminated most all the body roll I had.
#21 |
WHO. IS. SID?
Heresy! Heresy, I tell you! Get the torches and the pitchforks! ![]() Sid is VERY well known among car owners with straight axles. His stuff is as reliable as it comes.
#22 |
Ryan,
Did you have Sid redo your king pins? Modify your steering arms, the whole shebang? I've never driven one but have heard when the whole thing is done and is back to factory specs (other than the lowering of course) the steering and handling is simply an amazing change.
#23 | |
But yes, Sid did my kingpins and all. Full treatment. I will say that after all that work, with the Posies springs, rebuilt stock steering box, Bilstein shocks and sway bar...the truck drives and handles like a dream. It's my daily driver and with every improvement it just keeps getting more dialed in and fun to drive. It steered and handled downright scary when I found it.
#24 | |
All good info...no hijack
#25 | |
So...when are you cutting out your C4 stuff? ![]()
