Drop shackle help please
I have a 71 C10 with a leaf spring rear. I tried to install Crown 2 inch drop shackles, but the shackles hit the bottom of the wood bed floor. Has anyone else had this issue and how did you fix it?
Thanks for the help, Jason
71 C-10 "Ole Blue" ![]() 72 C-15 - Current Project 72 K-10 - In Pieces (Sold) 70 C-10 - "Goldie" (Sold) 66 Impala Convertible 20 FLTRXS |
Re: Drop shackle help please
Axle flip kit instead.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Post Whore
![]() Join Date: Aug 2013
Pix of the shackles. And is this part # exclusive to the earlier (yours) C-10's?
I assume it is hitting the crossmember and not the actual floor? If I remember on the instructions for the ones I installed on my C2500, if you went to the lowest point that crossmember had to be trimmed for clearance.
